InterNACHI
Go Back   InterNACHI Inspection Forum > Specific Inspection Topics > Structural Inspections
Notices
Structural Inspections Contains discussions about the structural portion of a home inspection. This includes foundations, framing, etc.
Reply
LinkBack Thread Tools
  #1
Old 6/24/08, 9:41 PM
nbhi's Avatar
nbhi nbhi is offline
InterNACHI Member
Default Post?
This was found on todays inspection. This is under a porch. My gut says the post should be set in concrete. Or am I going over board on this?
Attachment 22216
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison
www.newbeginningshomeinspection.com
  #2
Old 6/24/08, 9:52 PM
Jeffrey R. Pope's Avatar
Jeffrey R. Pope Jeffrey R. Pope is offline
InterNACHI Member
Default Re: Post?
The block is concrete, but it shouldn't be on its side. . .
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ®
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
  #3
Old 6/24/08, 9:53 PM
Christopher Currins's Avatar
Christopher Currins Christopher Currins is offline
InterNACHI Member
Default Re: Post?
On a concrete pad off of the ground is better than set in concrete. But setting on a hollow block turned sideways is bad.
Christopher Currins
Certified, Licensed
Proudly serving the St.Louis Metro
St. Charles, St. Peters, Maryland Heights,
O'Fallon, Florrisant, MO Home Inspector
BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
  #4
Old 6/24/08, 9:55 PM
nbhi's Avatar
InterNACHI Member
Default Re: Post?
Jeff
How else would you do it, fill the holes in the block?
  #5
Old 6/24/08, 9:57 PM
InterNACHI Member
Default Re: Post?
Quote:
Originally Posted by nbhi
Jeff
It would first need to be set up right. Replace with a solid block.
Christopher Currins
Certified, Licensed
  #6
Old 6/24/08, 11:04 PM
Jeffrey R. Jonas's Avatar
Jeffrey R. Jonas Jeffrey R. Jonas is offline
InterNACHI Member
Default Re: Post?
Can't quite get it right now, (very long day), but something else doesn't seem right. Have anymore pictures of this area? To the sides, or further out?
  #7
Old 6/24/08, 11:32 PM
InterNACHI Member
Default Re: Post?
How about here. And the 4x4 beam?
Christopher Currins
Certified, Licensed
  #8
Old 6/24/08, 11:50 PM
InterNACHI Member
Default Re: Post?
Quote:
Yes, those definately...but I'd like to see more to the sides and a broader view of the porch and it's framing. Is the porch enclosed? Is it's framing open to the elements? (notice vegetation growing underneath). Blocks may not be appropriate...may need actual footings set below the frost line. Picture reminds me more of a deck than a proch.
  #9
Old 6/24/08, 11:59 PM
InterNACHI Member
Default Re: Post?
Quote:
I agree, it looks like an addition to a porch, (porch, deck, combo) built by a first time carpenter.
Christopher Currins
Certified, Licensed
  #10
Old 6/25/08, 12:13 AM
Tim Spargo's Avatar
Tim Spargo Tim Spargo is offline
InterNACHI Member
Default Re: Post?
hmmm that's a lil funky.
The joists look like PT... is the post? Looks like it to me, not positive. I agree that the block in that fashion could use improvement as a support. Pre cast pier//?
We don't use 4 x 4 beams here, doesn't mean that locality doesn't (or didn't).
Permit research?
I think the access, if that's what it is to the left makes for a nice place for the local wildlife to get in...
cheers
  #11
Old 6/25/08, 8:31 AM
Michael Larson's Avatar
Michael Larson Michael Larson is offline
InterNACHI Member
Default Re: Post?
The whole "porch addition" looks funky and I agree it looks to have been built by Mr. Handy Homeowner with dreams of being a carpenter by "extending the original Floor josits and supporting the juntion with a 4 x 4.
And yes it should sit on some type of footing that goes below the frost line for Ohio.
The guy did use Simpson strong ties(at least 1) so I'll give him a point for that.
You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell
Never underestimate the difficulty of changing false beliefs by facts. - Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
Services provided in East MN and West WI
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Steel post question sspradling Structural Inspections 42 3/2/07 8:59 PM
Post your mold and IAQ videos for the public Iaqforum Deuitch IAC2 Indoor Air Forum 0 2/3/07 12:25 AM
New member trying to post Andy Frost General Inspection Discussion 8 2/1/07 4:23 PM
Support post for Beam, is this right? mlong Structural Inspections 74 7/25/06 7:47 PM
Popular Sections
All Sections
Inspection News
InterNACHI Membership
Inspection Standards
Inspection Education
InterNACHI Inspectors
Inspection Links
NACHI.ORG Statistics
no new posts
