Old 12/29/07, 6:44 PM
Matthew Hopkins Matthew Hopkins is offline
Please Note: Matthew Hopkins is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Post and Beam connection
Is it acceptable to connect post and beam in a crawlspace with scrap OSB as opposed to simpson ties?
Seems at the least to be less desirable as the OSB is much more likely to suffer deterioration from moisture, but i don't want to make a big deal of it if it's an acceptable building practice.
Old 12/29/07, 7:07 PM
Jeffrey R. Pope's Avatar
Default Re: Post and Beam connection
This set up is acceptable in many parts of the country, but it really depends on a couple other factors.
Is this a retrofit? If so, this would likely be acceptable as an "upgrade" to the support system.
Are you in a seismic zone or high-wind zone? This type of connection is not acceptable in CA new construction. We are in SDC D1 & D2 throughout most of the state. High-wind zones also require listed hardware.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/29/07, 7:12 PM
We're in Portland, OR and the seismic requirements ehre are always changing, but we are in a seismic zone.
This is new construction, not a retrofit.
Post & Beam Splitting dsmith1 Structural Inspections 9 2/16/10 4:04 PM
Pick the winner of the Super Bowl and win a NACHI Beam $109 value. gromicko Miscellaneous Discussion for Inspectors 161 2/6/07 9:33 PM
Is this beam OK? japanguy Structural Inspections 23 8/14/06 7:09 PM
Support post for Beam, is this right? mlong Structural Inspections 74 7/25/06 7:47 PM
