jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Does anybody know what would cause the end of a post tension cable to protrude the slab 1 to 2 inches. Is it possible for the post tension cable in a monolithic slab to fail and exit the slab in such a way. Any comments or links to information would be usefull. The home is less than a year old.
Thank you . |
Cable failure is usually pretty obvious.
It's possible that the cables were just not cut and sealed properly. A picture would help. . . In any event James, exposed PT cable is a defect, regardless of why it's exposed. Here is an example of cable failure. . . http://www.nachi.org/bbsystem/viewtopic.php?t=10052 IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 4/17/06 at 10:55 PM.. |
Jeffrey, thanks. exactly what I was looking for.
| Where's NACHI on this Website? | lcapaul | General Inspection Discussion | 77 | 7/31/07 4:00 PM |
| Hair line crackings in garage floor post tension slab | Henry Saputra | Structural Inspections | 18 | 4/3/07 12:43 PM |
| Pillar to Post member Frank Ross puts out nice press release. | gromicko | Miscellaneous Discussion for Inspectors | 1 | 8/4/06 1:05 PM |
| Ceilings falling with wires in it. | jsmith3 | Interior Inspections | 9 | 3/16/06 7:24 PM |
