Old 12/22/07, 1:25 PM
Ron Chorey II's Avatar
Ron Chorey II Ron Chorey II is offline
Default Post tension slab labeling
Aren't post tension slabs suppose to be labeled? Is the labeling usually put into the garage slab floor?
Old 12/22/07, 2:12 PM
gporter's Avatar
gporter gporter is offline
Default Re: Post tension slab labeling
On the garage foundation there is a stamp that says "Post tension slab, do not cut or core". Yes. There are machines that will find the cable and their placement. Residential is rare but is used in Texas. We have them in our jail that I helped construct. I watched it being done.
Gary Porter
GLP's Home and Mold Inspections
321-239-0621
Certified Commercial Mold Inspector
Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford
Orange County, Seminole County, Volusia County, Osceola County
www.homeandmoldinspections.com
Old 12/22/07, 3:51 PM
Jeffrey R. Pope's Avatar
Not rare at all in residential, in fact, it's very common.
The warning requirement only applies to residential. It is not required in commercial applications.
In residential, the slab should be stamped. Generally it's done in the garage so that it remains visible. If there is no stamp, there must be a permanent sign posted.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/22/07, 6:46 PM
gporter's Avatar
Really. I read it was rare. What states?
Gary Porter
321-239-0621
Old 12/22/07, 7:34 PM
Gary T. Heller's Avatar
It is common here in Arizona. i will attach a few pictures.
post-tension-slab-labeling-concrete.jpg   post-tension-slab-labeling-concrete2.jpg
Old 12/22/07, 7:37 PM
I was placing cables in residential foundations in the '80's. Almost every home built in the last decade or so in CA has a PT slab/foundation.
I think it's pretty popular in TX as well.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 12/22/07, 7:38 PM
Here is the stamp.
Old 12/22/07, 7:47 PM
bzimbelman bzimbelman is offline
I have yet to find one here in Silver, have you found some in Cruces?
Brian Zimbelman
Circle Z Inspection Services
http://www.circlezinspections.com
575-535-4481 (wk)
575-313-1281 (cell)
Old 12/22/07, 7:53 PM
If the slab is PT and there is no warning mark, it should be called out. Once the sidewalks are poured and ground cover is placed, it can be difficult to determine if cables are present.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 12/22/07, 8:26 PM
Default Re:Framing
While I am talking to the structure experts let me ask this. What determines where they put the siding on the vertical walls. I watch a lot of homes being built and I can find no rhyme or reason to where the chip board is added and where it isn't. I would like to see a set of plans that the framers use but so far I haven't had the chance.
Old 12/22/07, 8:33 PM
Generally, it has to do with the required shear-strength (the design strength) of the wall. Sometimes it's paneling (as you have pictured), and other times it will be steel panels or "strong-walls."
post-tension-slab-labeling-shearwall.jpg   post-tension-slab-labeling-shear.jpg
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 12/22/07, 8:40 PM
I haven't seen the steel. Is it common to see some walls with no panels? Here in AZ I have seen the same model, one house facing north and the other facing south with the chip board on different walls. Prevailing winds???
Old 12/22/07, 8:47 PM
Possibly. It's all a matter of "design criteria" in your area. Most of CA is in SDC 1 and SDC 2 (Seismic Design Category), so these steel panels are common. AZ's designs are (I'm sure) different from ours.
Where the wall dimensions limit the amount of lumber that can be used to obtain the required strength, these strong walls are the substitute.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 12/22/07, 10:06 PM
gporter's Avatar
I will try to find pics of the ones at the jail
Gary Porter
321-239-0621
Old 12/22/07, 10:17 PM
gporter's Avatar
Here ya go. Orange County Florida Jail
Gary Porter
321-239-0621
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
Hair line crackings in garage floor post tension slab Henry Saputra Structural Inspections 18 4/3/07 12:43 PM
post tension cables jlybolt Structural Inspections 2 4/17/06 11:55 PM
