It's been some time since doing a pre-pour and am scheduled for one later this week. Are there sources out there to help cover all the bases. I've got a pretty good idea of the items to look for but wanted to make sure all my i's are dotted and t's are crossed. Thanks for any direction YA'LL!
Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
Richard,
I would inspect it to the code your municipality is currently using. Not knowing what type of foundation your referencing I cannot help. If your municipality is using the IRC, (without any local ammendments) post what type of foundation this is. Slab on grade, footings-stem walls with slab, basement, post tension, etc? Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Double post..oops.
Probably 99.99% of SE Texas foundations are slab on grade. How many are PT -vs- rebar I don't know. Richard...here is a good website for your area that you may already have but, if not, it may give you some pointers. There's no true checklist at this website though. Try: http://www.houston-slab-foundations.info/
Yes, it was a PT. Thanks for the site. I think I have seen that one a while back. Will save it this time around.
| InterNACHI's accessibility checklist being used in approved real easte course. | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 1 | 11/7/07 7:02 PM |
| Texas inspection report NCR checklist | jonofrey | Miscellaneous Discussion for Inspectors | 9 | 10/17/06 10:25 AM |
