If a fellow NACHI member could further guide me...I know what the books say about notching a floor joist. What are the concerns for notching a 2 x 10 floor joist to accommodate a 3 in drain pipe to pass through. My thoughts are; that almost 1/3 of the board would be missing since the board is not exactly 10 in wide.
Some input would be helpful Thanks </IMG> Dave Johnson East China, MI NACHI06081990 |
This may be helpful.
bandag is a non-member guest and is in no way affiliated with InterNACHI or its members.
Mike, where did you find that picture?
I'd install some additional additional support in the form of one or more metal bars, boards, or the like extending at least 2 feet (or to the end) on each side of the notch, and attach it at no less than 6 points (3 each side of the notch), David.
I don't know the specific codes for such reinforcements, but since you're making about a 3.5-4" notch it stands to reason that a well-attached 2x6 or metal bar of equivalent strength should be more than sufficient. When in doubt, overbuild. And thanks for the schematic, Michael. |
| PVC waste lines | lagudo | Plumbing Inspections | 10 | 3/6/11 1:57 AM |
| Electricians Check List | pabernathy | Electrical Inspections | 74 | 12/5/07 6:39 PM |
| What is the proper name of this "monster"? | yolhovsky | Ancillary Inspection Services & Additional Topics | 34 | 11/15/07 1:35 PM |
| Unable to confirm proper ground.. | gmathias | Electrical Inspections | 22 | 10/27/06 8:20 PM |
| Are these proper connections? | jweinberg | Plumbing Inspections | 9 | 5/25/06 8:32 PM |
