This 6,000 sf new home had a triple joist being supported by a piece of 2x8 & 2x4 and then supported by two 2x4's. Not sure why they were doing it like this. This was in the kitchen. You can also tell there is a versalam beam perpendicular to the joists. Alot of weight in this area...
I recommended triple studs directly under the top plate so the load would be transferred properly. Any thoughts? Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
| Need a home inspection in Rhode Island? Check out InterNACHI's listing of Rhode Island certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I agree that a triple stud below the top plate, below the triple joist is needed. The pictured support does not seem to make a lot of sense. It's interesting that the wall has double studs across it. What was the purpose of that. What is this wall supporting above?
774 Manor Road Staten Island, NY 10314 718-514-3393 |
The 2x8 & 2x4 appear to be acting as a ledger. There should be a substantial support transfering the load directly to the foundation.
I would refer it to an engineer, but would not recommend a certain fix. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
If a person recommends a triple stud and the continued support below a floor, direct to the foundation, is forgotten, it would be problematic. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
This whole thing looks like temporary supports to me. For one thing the drywallers are going to have fits when and if they come to this area. Even if this is fixed, the hanger bracket for the laminated beam was put in poorly and extends or hangs down below the bottom of the ceiling joists.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill Last edited by dedwards; 12/28/11 at 4:12 PM.. |
Not proper support write it up.
With out knowing the loads the proper support may be more than three 2x4, plus you have to check the load path and make sure the load is properly transferred to the foundation. Don't tell them what to put in there just state it is not a proper support. |
Or you could say; According to good practice the support should transfer the load to the foundation and may not be a proper support. This should be confirmed by a qualified individual.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
I agree, do not recommend a fix.
This picture does not show the whole picture. You have three 2x8" joist supported on a ledger and 2 2x4's which looks like temporary, but ledger alone is not adequate to support that beam which appears to be supporting a substantial load unseen to us. That built up beam is bolted with a couple of sandwich layers unknown indicating extra strength needed to support that PSL, or at least it looks more like a PSL than a Versa-lam or LVL. Refer to Architectural Drawings, or defer to an Architect or SE for determination of it's adequacy. If you look close, the built up beam is headed off indicating it is not bearing on the stud wall. Weird framing for unknown reason from this end. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Thanks for the input. I am waiting to hear back from the Super as to the path forward.
I'm scratching my head with the framing method from the "top plate" upwards. Who rests the subfloor directly on top of the ends of studs? And what's up with the 2x4 running perpendicular from the lam beam in the top left of the photo.
The tripled up joists look like a triple flitch, and there doesn't appear to be enough through-bolts. |
Richard,
I'm just guessing from pic, but looks like the installed blocking prevented bearing on plate (see pic) or maybe there was/is hardware there? Beam pocket or other may need to be built... maybe alters load path and foundation... fun More bolts Darren? Now you sound like some of the SE's that would write up correction details Home Inspections in Palmdale Lancaster California Tim Spargo Spec Rite Inspections Commercial and Residential Inspections Palmdale Lancaster Santa Clarita CA 661-317-5770 Last edited by tspargo; 12/31/11 at 1:12 AM.. Reason: edit |
Marcel was just pointing out that you could have taken better / more pictures.
Yes, there are blocks however it doesn't show if its blocked between what appears to be bolted I-joist. If that blocking is continuous then its a no brainer..... just saying.... |
Based on the pic, the hangar and bolt pattern, the beam can't be for support. Is it solid? Do not understand why framers would need a temp support for any reason as framing is landed on top plate; so why would it need any bracing? Initial assumption would be the span was figured as such. I would go to plans and refer back to architect for clarification.
www.thebuildinginspector.net William Chandler Licensed Home Inspector #1025 Certified General Contractor #CGC060389 FHA 203(k) Inspector #A0954 Licensed Radon Measurement Technician #R2275 Certified Pollutant Storage Systems Contractor #PCC052624 Certified Underground Utility & Excavation Contractor #CUC057349 |
| Deck support | dokeefe | Exterior Inspections | 16 | 6/25/09 11:42 PM |
| Electricians Check List | pabernathy | Electrical Inspections | 74 | 12/5/07 6:39 PM |
| Floor support posts | kgerhauser | Structural Inspections | 7 | 7/17/07 12:23 AM |
