Old 1/12/14, 10:54 PM
Marcel Gratton, CMI Marcel Gratton, CMI is offline
Default PWF
I inspected a Permanent Wood Foundation today where the customary 6 mil polyethylene exterior moisture membrane was an ice and water shield type.
My first thought was that is better than poly but I would like a second opinion. The missing plywood strip at grade level was noted.
Thanks!
On The Level Inspection
Gatineau, Québec
Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/12/14, 10:57 PM
Bob Elliott's Avatar
Default Re: PWF
Never saw a wood foundation.
Have any shots showing the actual wood ?
If that 6 mil rips is the wood exposed and prone to rot ?
Old 1/13/14, 12:15 AM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is online now
Location: Cuernavaca, Morelos, Mexico, (from Boulder, CO)
Default Re: PWF
I think of them as Powdered Wood Foundations and disclaim them. Only seen two, both bad and I don't trust them. Proper inspection requires probing through the ground around the foundation with a 6' metal rod. My understanding is that they can last a while, maybe 30 years, if built correctly, but that's a big IF and failure to build correctly turns one of the major structural components of a building to mush in not much time. They're the Yugo of foundations in my opinion.
Kenton Shepard, CMI
Director of International Development
Director of Green Building
EXPERT WITNESS SERVICE
www.hinarratives.com
052 777 246 4676 (preferred)
052 777 154 5451 Cell
INSPECTION SERVICES WORLDWIDE
Old 1/13/14, 10:00 AM
Default Re: PWF
Not too many around here either but they are cheaper to build than concrete and are more popular in remote areas.
If that 6 mil rips, the wood foundation is compromised and prone to rot. As we know even treated wood rot.
Some good info at link below, click on Publications, PWF Design & Construction Guide (you must provide an email address to gain access).
http://www.southernpine.com/
Gatineau, Québec
Old 1/13/14, 10:01 AM
Default Re: PWF
Originally Posted by jjonas View Post
Good video Jeffrey, I'll send the link to the client.
Thanks,
Gatineau, Québec
Old 1/13/14, 11:19 AM
Greg W. Mathias's Avatar
Greg W. Mathias Greg W. Mathias is offline
Default Re: PWF
About 80% of the homes here have wood Foundations here. I have built hundreds myself. Poly on the exterior is not required as long as there is a moisture barrier of some sorts. We use a waterproof bitumen here. Tar all of the nails and joists first and then two to three coats of the bitumen. We do not use The grade level plywood strip as the engineers do not require it here. I know that PWF foundations get a bad wrap most of the time but I can honestly say I see more issues with concrete then PWF.
Old 1/13/14, 12:12 PM
Default Re: PWF
Thanks for the info Greg!
Gatineau, Québec
Old 1/13/14, 12:23 PM
kwood kwood is offline
Banned
Please Note: kwood is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: PWF
Only good location for a PWF is on the top of the hill. However if done correctly in the right location it will give less trouble than some concrete foundations.
Old 1/13/14, 12:26 PM
Jeffrey R. Jonas's Avatar
Default Re: PWF
Required by the engineer or not, missing grade level protection is always called out in my reports. It is (supposed to be) there for a reason! Whenever I see the protection is missing, 9 out of 10 times there is damage from lawn mowers and weed whackers!
Default Re: PWF
Completely disagree with this statement. If built properly they are good in any location.
Have you Inspected many in your area?
Old 1/13/14, 12:30 PM
Default Re: PWF
I would be calling up every home I inspected if I called up the grade level protection. The parging is there to protect it. That is mandatory in our area as the UV light can break down the plywood fairly quickly.
Old 1/13/14, 12:38 PM
Banned
Default Re: PWF
Not as many as you but I have seen them sink crack lift on clay soil. Unfortunately here in SSM clay is everywhere. I would not use any PWF that might get wet for a period of time during flood season. Also Parging or Damp proofing is very minimum protection in my mind and will not stop water like a cement foundation will with proper draining and foundation dimpled protection.
http://www.supersealonline.us/catego...6-Accessories/
Old 1/13/14, 7:08 PM
Michael Larson's Avatar
Default Re: PWF
Kenton is has let two PWF affect his opinion.
He needs re education.
That is all.
As a Professional Home Inspector, I support the privacy of my clients.
For more information click Trustyourinspector.ORG
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
