I've only inspected two of these and stuck a screwdriver right through the treated plywood in both homes. Ever inspect any of these over 20 years old that were good?
Kenton,
I never even heard of the term "Powdered Wood" foundation...you have any pic's. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
"Powdered" is a reference to their condition after 20 years of being considered "permanent."
I want to see Kentons pic's of a Powdered Permanent---I have never seen one of those either..... What is it?....a plywood basement wall system?....or stem wall?......I don't think Kenton mentioned basement...but I'm taking a wild guess.....
http://www.askthebuilder.com/EM0013_...ndations.shtml
I have inspected too many and do not have much love for them . Did Four recently two the bought two walked away. .. Cookie If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
Anyone have any pictures of a bad one they inspected? Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
.The out side was covered with cement Board to below the ground and inside are completly finished . Usually warm and dry. ... Cookie If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
Great Pictures thanks Marcel,
Have you ever built one and do you have an opinion on them . ...Cookie If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
Have built, worked with or around 15+ PWF's since 1980. Actually just mentioned on another thread a few days ago that these were my favourite foundation. Last one I supervised/worked on was for a former employee/friend in 2000. We had his large 1882 house excavated/blocked in place by a housemover and then built the PWF under the dwelling.......took a full 7 days for 4 of us.......but the house had 18 inside/outside corners to frame under, not counting 3 on an attached but unexcavated shed. This was in heavy clay soils and he has had no problems as of yet. The oldest PWF in that area of New Brunswick is now 30 years old and has had no problems. I check in with the owners every 5-6 years or so to enquire about it. I built a new home for a client on a lake in 1987. The wood foundation has had no problems that I know of. A minor water entry problem developed when through a couple of of reinforcing changes made by (1) the second owner- putting in a new submersible sump pump for its quietness while inadvertently raising the water level in the sump pit- and (2) an excavation contractor- he raised the drainage and general water table level in the area while preparing his own site for building!! This also killed a number of 30-40-50 year old trees with water covering the root systems!! The water problem was easily solved in the end. If PWF's are built to widely recognized standards, there should be no or minor problems only. Owners consider them to be dryer and warmer than concrete foundations. If built without concrete footings directly on local soil but with a wood footing plate on a minimum 5" compacted gravel base, a foundation perimeter drain tile is not needed. The CSA standard for them here has been made less stringent over the years as they are performing admirably and better than expected. I would check out the certifying agency, standards, etc for the preservative treatment....sounds like somethings amiss there. Quote from a PWF site (forget its origin): "Wood foundations originated in 1938, following the development of preservative-treated lumber and plywood designed to resist decay from moisture and infestation from insects. To date, over 300,000 homes in the U.S. have been constructed with wood foundation systems." A great reference manual is found at this site: http://www.cwc.ca/Publications/Book+Store/index.htm http://www.cps.gov.sk.ca/A13Advisory.pdf http://www.woodfoundation.com/ http://www.toolbase.org/Technology-I...od-foundations |
cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Brian, I have to agree with you having built 18 of them myself. If they are done properly they should never "see" any water. I think one of the common misconceptions is that the wood is the kind you go down to the orange tool box to buy.
Bad grading is the rule rather than the exception in homes around here, so building (or buying) a home with a foundation which basically disolves (decays) when exposed to moisture over the long term seems like a really bad idea. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
These homes were both 30+ years, plywood was green. I imagine a lot of the problem is the fact that they need to be built to certain standards and builders in the past haven't bothered to find out about standards or what's important in building these types of foundation walls.
I've only seen wooden foundations twice. Both times, the foundation resembled rail-road ties - size and shape - staggered and stacked two high with vertical through-bolts. Both times, they had significant infestation (rot & insects) and were on Desert homes.
I know of no CA jurisdiction that allows this type of foundation for "habitable" spaces. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 12/26/07 at 1:00 PM.. |
| Can someone explain why wood in contact with concrete causes rot? | gromicko | Miscellaneous Discussion for Inspectors | 46 | 1/17/11 12:15 AM |
| Preventing Moisture related Problems | mcyr | Ancillary Inspection Services & Additional Topics | 1 | 12/19/07 9:30 AM |
| Common Defects List by Age of House | trausch | Inspection Education & Training | 10 | 6/12/06 5:52 AM |
