Doing phase construction inspections on a new house (for the builder, who is unexperienced (go figure)).
They have the beams in. Look at the post in picture 1, right in the center (not plumb), but especially, look at the mating of the beam from the right (picture 2). Is this mating OK? The beam from the right is not supported from below. BTW: The backfill guy broke or bent about 1/2 the sill plate bolts (Picture 3). Comments? How would you write this up? Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Sorry Will, I don't see anything wrong.
Looks like a regular engineered system. The unsuported beam connection is no different than bridge beams that I have seen and most of the time that same connection will be three to five feet away from the support column depending on load above. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Looks like a pretty standard connection to me as well. They'll plumb these up when they start dropping floor joists.
The damaged bolts would require an engineered repair in my area. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Where do you see the damaged bolts? Must have missed that unless it is the third picture that I could not define. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Thanks, guys. I don't know why the didn't use the same size (height) girder all the way across and why they didn't support it on the post.
Thanks again. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
By the way, I blew up the picture and noticed there is no bearing plates and anchorbolts on the steel columns. I would be curious as to how they set them the right height. Typically, you would see a baseplate on 3/4" of grout or leveling nuts to set the columns. Any idea.? Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Bad handeling of the Bobcat. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
That's bad. Luckily, Simpson manufactures a strap that can replace those damaged anchor bolts. . .
Bent bolts are common and usually not a problem, but bent to this this extreme, once it's been straightened it'll be weaker than original specs. Pass on the liability. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
They can be bolted to the side of the wall. . .
I douby they would go to this extreme, chances are they would drill and use quick bolts or wedge bolts and probably not be galvanized nor stainless because of the PT. contact.
![]() LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
That's exactly what they use Marcel. Used to replace damaged or missing bolts, and for seismic upgrades to old, unbolted foundations.
actually the J bolts need to be replaced, only because the bolts are bent to close to the 2 corners meeting together. If the bolts were more further away from the corners, they can just use a nail gun to sink in support, as we did for inner walls. Also depends on what state requirements are for Earthquack anchors for the corners. I'll need to check my IRC or IBC, and get back with you guys, on what it will call for.
I know Southern Calif has to have Earthquack anchors on both sides of the corners, on all 4 corners of the home. My family uses them on every jobsite, for homes and apartments. Missouri Home Energy Auditing Services Residential & Commercial Inspections Serving Central Missouri Certified Missouri Home Inspector InterNachi ID # 07110204 Environmental Inspection Solutions & Services Thermal Infrared Imaging-Certified Thermographer Energy Audit Consultant/Survey-Inspector CMC Home Tune-uP Certified ID # 1505 E.S.A. Certified Mold Inspector & Assessor CMI CMIA Last edited by asargisian; 4/7/08 at 8:42 PM.. |
Marcel I have seen similar ones of those anchors, on commercial jobs but not residential. "Not Yet"
Missouri Home Energy Auditing Services Residential & Commercial Inspections Serving Central Missouri Certified Missouri Home Inspector InterNachi ID # 07110204 Environmental Inspection Solutions & Services Thermal Infrared Imaging-Certified Thermographer Energy Audit Consultant/Survey-Inspector CMC Home Tune-uP Certified ID # 1505 E.S.A. Certified Mold Inspector & Assessor CMI CMIA |
| Got a letter from ASHI's President today. | gromicko | General Inspection Discussion | 55 | 12/12/10 11:51 PM |
| Answer to a common question about GFCI's | jtedesco1 | Electrical Inspections | 4 | 1/12/06 9:29 PM |
