-During a Phased Inspection, I noticed that the builder had either ‘cut’ or ‘enlarged the cuts’ in numerous wood I-Beams so he could run HVAC flex duct through them. In my report, I stated that ‘Field Modifications’ are ‘not allowed’ to Wood I-Beams. (The holes were ‘not’ pre-defined knockouts)
-The builder responded that “it is only the middle third that cannot be modified”. I do not believe he is correct. As I see it, the corresponding IRC code reference is 502.8.2, “…..or I-joists are not permitted unless the effects of such penetrations are specifically considered in the design of the member.” -Am I correct, that this means NO field modifications are allowed on wood I-Beam Joists, regardless of ‘where’ they are in the joist span.? Rodney Sims (Real Estate inspection Specialist) (with 'INFRARED' Thermal Imaging) CELL: 713-829-7732
| Need a home inspection in Oklahoma? Check out InterNACHI's listing of Oklahoma certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Field cuts are typically allowed. Check with the specific manufacturer and keep the cuts within their specifications. For example, see page 1: http://www.ilevel.com/literature/TJ-9001.pdf InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
I agree with Larry.
PS... Welcome !!! Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
| Mold Resistant Wood by FrameGuard | mcyr | General Inspection Discussion | 15 | 1/16/09 9:14 AM |
| National Field Rep. question? | mwood1 | General Inspection Discussion | 2 | 12/11/06 3:36 PM |
