Old 3/8/06, 9:05 AM
thejnicki's Avatar
thejnicki thejnicki is offline
Default Rafter Overlay
Roof type was a hip roof with concrete tile covering. Attic is truss and rafter framed, take a look at the way the builder overlapped the rafters in this particular area. My question; Is the overlapp enough & are there a suffiecient amount of nails tying them together?
Thanks To All.
Old 3/8/06, 2:23 PM
David P. Valley's Avatar
Default Re: Rafter Overlay
Tim,
Welcome to NACHI.
I'd like to see bigger pictures.
Is that the only 2 X that was cut in this area?
It appears that there's no bearing on that rafter end. This repair looks like a shoddy repair from here.
Old 3/8/06, 3:47 PM
It appears that the lower rafter is bearing on a purlin (if that's what it is, can't tell from this photo) but the upper rafter is not, meaning that it is depending on the shear strength of nails to carry the load it supports. Good framing practice would have both upper and lower rafters bearing on framing.
I might physically point it out as an example of poor framing practice but it's not a defect and I wouldn't call it as defective or recommend an SE unless I saw evidence of failure, meaning separation between rafters/nails pulling loose. -Kent
Old 3/9/06, 6:08 PM
Robert J. OConnor's Avatar
Although the pics are blurry, it looks like maybe 2 (maybe 3) 8d or 10d nails (no thru penetration) at a location with heavy vertical/shear load. For rafters under a decent snow load or wind uplift it wouldn't be adequate, and there does appear to be some separation of the members. Look at the IRC nailing schedules for a rough idea if you are curious.
I would recommend evaluation/repair by a licensed framing contractor.
JMO & 2-nickles
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 3/9/06, 10:14 PM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
i think the best way would be to lag them to gether, but if you have to use nails, i agree that 2 is not near enough. find the code, indrease it by 50% and recommend.
Are roof rafter notches allowed rchorey Structural Inspections 25 2/23/09 8:05 PM
Ridge Board....What's That? pabernathy Structural Inspections 35 2/22/07 11:25 PM
Acceptable roof rafter repairs ldapkus Exterior Inspections 14 7/17/06 11:49 AM
Overnotched Rafter hspinnler Structural Inspections 23 1/8/06 5:55 PM
