Is there a distance/offset on either side of the ridge beam that rafters are allowed to be connected to ridge.
Typically rafters are adjacent to each other at the ridge beam. |
They should be adjacent to each other. R802.3 Framing details. Rafters shall be framed to ridge board or to each other with a gusset plate as a tie. Ridge board shall be at least 1-inch (25 mm) nominal thickness and not less in depth than the cut end of the rafter. At all valleys and hips there shall be a valley or hip rafter not less than 2-inch (51 mm) nominal thickness and not less in depth than the cut end of the rafter. Hip and valley rafters shall be supported at the ridge by a brace to a bearing partition or be designed to carry and distribute the specific load at that point. Where the roof pitch is less than three units vertical in 12 units horizontal (25-percent slope), structural members that support rafters and ceiling joists, such as ridge beams, hips and valleys, shall be designed as beams. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
I couldn't find it in THE BOOK either. Today they were offset about 8 inches on either side.
Thanks for the response Dale. |
2003 IBC:
Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! |
Dale,
Agreed!! If interested you can obtain an IRC membership and get a good discount on the entire, various code series including ANSI specs. But have you seen even the discounted price? There was a lawsuit not long ago against a Texas resident who posted the entire code volumes on a WEB site. It sparked a big debate on having to even pay for on-line access to code manuals. By the way did you see this one? www.nfpa.org/newsReleaseDetails.asp?categoryID=488&itemID=29739 Would be nice if they could just all get along! But this is just another display that Codes have just turned into another money making business!! Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! |
ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Just to add.
Want to put some thoughts to rest for myself. Please correct anything that is incorrect or add: 1. A ridge board is not usually designed to carry any load, just something for rafters to attatch to. - except for in valleys ( not technically a ridge board ) 2. Rafters connected to a ridge board rely on being directly accross from one another to help support the ridge of the roof. 3. Rafters that are offset from one another can cause undo stress on the ridge board itself being that there is no rafter opposite it. |
rrichards2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Helm Home Inspection David Helm, Owner/Inspector http//www.helmhomeinspections.com |
The IRC has no specific provisions for alignment of rafters when a ridge board is used, and I think that is reasonable given the relatively light lateral loads against a ridge board on typical house framing.
The IBC (applies to large multifamily and commercial) is more restrictive than the IRC as the loads are expected to possibly be higher than typical residential framing. IMO it's no big deal if there is a offset between rafters on either side of a ridge board for typical residential framing. JMO & 2-nickels ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
Robert you are absolutely correct (see below)! Thank you for pointing that out.
IBC: Quote:
You are right Robert. The offset is not a big deal from a structural perspective and there may not be any code reference for it. However, good framing practices would have them directly opposed. This is the way I was taught by several Master Carpenters over the years. We all know that building code sets only a minimum standard. I certainly would not buy a house that was built to minimum code standards. Here I am in my younger days. Last edited by rrichards2; 8/24/06 at 6:25 PM.. |
ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Ever try putting collar ties on rafters that aren't adjacent to each other?
It looks/is 2nd rate and the fasteners don't penetrate fully when every thing is angled to everything else. I personally think if the house isn't stacked from joist to rafter it's not much of a house. But that's just me. |
| A new way of getting plenty air flow at the ridge | kshepard | Structural Inspections | 1 | 9/11/07 11:08 PM |
| Grounding rod connection from meter box | fbartlo | Electrical Inspections | 37 | 7/28/07 12:30 PM |
| Ridge Vents | kmcmahon | Exterior Inspections | 18 | 7/19/07 2:27 AM |
| Rafters separating from ridge board | jmichalski | Structural Inspections | 8 | 3/13/06 8:52 PM |
