Realtor says been this way 30 years. Im looking for something in writing to show this is not correct.
Any help is appreciated. Thanks |
| Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
For one, the blocks are not stacked correctly. The 'hollow' should be going up and down, not front to back. That should get you started.
anyone have IRC stating this is wrong?
NACHI education course covers it well.I believe the structural course. It has been a good reference guide for me. And it's included in membership. : )
There are so many things you could put but simply advise your client that the piers (and possibly the footings) were not constructed in regards to acceptable building practices and possibly local / state codes, ie. (insert improper or lack of footings, improper installation of C.M.U.'s, no mortar to give structural stability, etc) Recommend that a licensed General Contractor do a detailed inspection of the foundation and make necessary corrections.
Jeff PS. You do not need to cite code and unless you are also a GC or Engineer, I would not even go that route. |
Steve,
If I get a chance, I will be glad to send you some pictures of a home I inspected today as a GC to offer up an estimate for my clients......their foundation also was built similar (dry stack, improper installation of CMU's, no footer, improper girder sizes, etc).......yet they will be forking about over $10,000 for me to come fix it. Unfortunately they never had a home inspection prior to purchasing the home..... your clients were wise enough to call you..... dont be intimidated by an over zealous agent wanting a commission. Jeff |
forget code they are not installed to the manufactures specs. Recommend a structural engineer to devlope a scope of work for repairs
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Thanks guys. This realtor is a know it all guy who insists he sees this all the time and I am being nit picky.
Thanks for the input. |
Typical response from some realtors. It may have been this way for 30 yrs and so far no noticeable deflection in the intermediate floor components. This does not change the fact that defects were discovered with the structural supporting columns and they should be evaluated by a structural engineer who may require repairs and discover further defects because it is a non-typical installation.
"He is no fool who gives what he cannot keep to gain that which he cannot lose." Jim Elliot 1949 Gerald Wilcox Harvey, ND CMIA, RMT www.housecheckhomeinspections.com www.homeinspectorinnorthdakota.com 701.324.4075 Minot, ND Home Inspections Devil's Lake, ND Home Inspections Bismarck, ND Home Inspections Jamestown, ND Home Inspections Home Inspector in North Dakota North Dakota Home Inspection |
I would defer to an engineer for further evaluation and course of action. A contractor created this mess in the first place and might think it is just fine.
In CA this is an easy call - tear it out and start over.
For those of you in the more boring states ( You don't need an engineer, just a qualified contractor. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
IRC 2003 606.5 When used to support beams or girders...where hollow, masonry units are solidly filled with concrete or Type M, S or N mortar.
Sad but true. |
Structural engineer. We call those temporary supports here.
Greensboro Home Inspection Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas. greensboro-home-inspection.html Raleigh Home Inspection Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas. Raleigh-home-inspection.html BassRumors.com Providing a blog, news, and forum dedicated to bass fishing. |
Remember when the Mississippi River bridge collapsed in Minnesota a few years ago? That bridge had stood that way for forty years before it collapsed and killed people. The fact that something hasn't failed yet is no guarantee that it won't and is completely irrelevant in assessing whether it is done properly or not." Actually, you have been given good references in prior posts. I wouldn't respond this way except to shut-up the most egregious boundary over-steppers. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
| Free Books And Articles For Electrical | jtedesco1 | Electrical Inspections | 14 | 1/6/08 6:45 PM |
| Imagine There's A Heaven | jmckenna1 | Miscellaneous Discussion for Inspectors | 3 | 12/23/07 11:15 PM |
| What's Wrong Here? | jtedesco1 | Electrical Inspections | 10 | 12/9/07 9:36 PM |
| Whats wrong in this pic | cbottger | Inspecting HVAC Systems | 11 | 3/11/07 6:16 PM |
