Old 3/13/11, 8:35 PM
Bob Elliott's Avatar
Default Rear addition at 1965 home
Read that as 1955 however this forum does not allow edit of title.
Need help on this one as I really struggled with my report comments on this one.
I recommended a contractor come out and give opinion immediately however can someone please tell me what comments you would have on the way this was put together.
Thank you for any helpful answers in advance.
Somehow inviting a river to the inside of a structure seems so wrong.
Obviously they had a enclosed porch at the rear in the past and the doors were the entrance to the basement .
The top picture shows the rear siding under the deck where the old stairs began.
[ATTACH][ATTACH][ATTACH][ATTACH]rear-addition-1965-home-addition-under-deck-abandoned-stairs-1024x768-.jpg[/ATTACH][/ATTACH][/ATTACH][/ATTACH]
To try and explain better that rear addition is built over the old basement stairs and part of top of the stairs is outside allowing water into the underside of the new addition where it flows down the stairs into the drain which is actually placed in front of those doors which lead to nothing but a wall now as the laundry room is on the other side.So the green door is nothing but drywall on the reverse side.
Here is a picture under the deck showing the top of those stairs.
Click image for larger version
Name:	addition under the deck-abandoned stairs [1024x768].jpg
I hope this makes sense. as all pics are below that addition at rear except for the under that deck view .
rear-addition-1965-home-addition-looking-toward-exterior-1024x768-.jpg   rear-addition-1965-home-addition-north-west-corner-1024x768-.jpg   rear-addition-1965-home-addition-broadview-1024x768-.jpg   rear-addition-1965-home-addition-doors-under-1024x768-.jpg
Need a home inspection in Wyoming? Check out InterNACHI's listing of Wyoming certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/13/11, 10:44 PM
Default Re: Rear addition at 1965 home
Bump
No opinions?
Marcel?
Old 3/13/11, 10:58 PM
Christopher Currins's Avatar
From what I see, something like this.
The construction of addition at rear of home over original basement stairway entrance is amateur and inadequate and was not constructed according to standard workmanlike practices. Water intrusion, unstable support post, wood to ground contact, all noted at time of inspection. Recommend a reputable, qualified, carpenter evaluate further and make all necessary repairs and/or replacement. Also to determine a method to prevent future water intrusion.
Christopher Currins
Certified, Licensed
Old 3/13/11, 11:01 PM
Jeffrey R. Jonas's Avatar
The construction of addition at rear of home over original basement stairway entrance is amateur and inadequate and was not constructed according to standard workmanlike practices. Water intrusion, unstable support post, wood to ground contact, all noted at time of inspection. Recommend a reputable, qualified, carpenter evaluate further and make all necessary repairs and/or replacement. Also to determine a method to prevent future water intrusion. Installl proper deck flashing which diverts water to underdeck gutter system.
Done deal!
Old 3/13/11, 11:03 PM
Bob,
So if you open the green storm door, all there is is drywall? No framing in of the doorway? Or exterior siding, at least an exterior door?
Old 3/13/11, 11:07 PM
Originally Posted by jjonas View Post
Done deal!
Nice......
Christopher Currins
Certified, Licensed
Old 3/13/11, 11:17 PM
Nice......
Thought you may like that!
Bob must have fainted!!
Old 3/13/11, 11:34 PM
Yeah ,under deck gutter system (very common) see them all the time.Who are you ...Joe Peshi in Casino.
Those doors are surrounded by the crawlspace entered through a old window at rear of the full house basement .
I crawled to get to that area so imagine my surprise to see this area.
Also the corner of that crawl area I am showing has the catch basin part under the wall.
I agree with what Chris said and not so sure about the framing either plus I forgot to check for Tyvek.Called my client and made the suggestion for a good contractor to check it out before closing but I have never seen it done this way and as mentioned I doubt water running under siding and down closed off stairs into a drain at the bottom is acceptable.The room above is an extension of the kitchen so the space needs insulation and to be conditioned along with many other issues. Wish I could have just done a video on it and should have, as the rest of the home is video.I was just shocked at the time to see the space and how it was done.
Yes the other side of the doors is drywall with laundry there at back of regular basement .
To me this space is like a poor constructed enclosed porch but is part of the home upstairs.
Old 3/13/11, 11:40 PM
Here is a look at the addition from inside the home.It starts at end of the kitchen area.
Old 3/14/11, 3:30 PM
Looks like one hell of an abortion to me.
Recommend a Licensed Contractor to fully evaluate the condition and repair to meet todays standard in renovation.
How can so many things be wrong.?
Old 3/14/11, 3:48 PM
What, you don't like my "gutter" idea?!?!?
Hope you're having a great day, Marcel!!!
Old 3/14/11, 3:55 PM
Hi Marcel
I told the guy I would call with opinions from professional Inspectors.
So far we already know to have it evaluated but how would you have done it?
Would you have done something with that stair pit ?
Insulation is easy.
What about the framing and siding?
Old 3/14/11, 3:56 PM
Yeah let me pass that on with a link to your contact info for all the Realtors in your area Jeff.
Old 3/14/11, 4:31 PM
Originally Posted by belliott View Post
Hi Marcel
Insulation is easy.
Bob, it is hard to relate where those areaways are in the pictures.
One with plywood that is leaking water and the other with the screen door.
I can figure out that the door in the brick is on the original house, but where is the other and how are they both accessed?
Not enough of the whole picture to make a recommendation.
Old 3/14/11, 4:35 PM
Linas Dapkus's Avatar
Linas Dapkus Linas Dapkus is offline
Are you bidding on the fix or are you doing a home inspection? Report that it's wrong and move on.
Orange County Home Inspections whandley California Inspectors 12 5/18/11 6:35 AM
Coeur d'Alene, ID Home Inspectors rspriggs Miscellaneous Discussion for Inspectors 12 1/8/09 5:16 PM
Inspector Wendy's Home Inspections-Service Areas wforsyth Miscellaneous Discussion for Inspectors 57 9/5/06 11:10 PM
