Old 6/6/09, 6:14 PM
John Evans John Evans is offline
Default Result of Improper Door Installation
Discovered considerable structure damage concealed behind rim joist insulation. This area is directly below a sliding glass door, home built 1990.
It pays to look behind the rim insulation, I have discovered similar issues on previous inspections, mostly below doors.
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Find an InterNACHI certified South Dakota Home Inspector (and anywhere else in North America)
Old 6/6/09, 6:41 PM
Billy Boerner's Avatar
Billy Boerner Billy Boerner is offline
Send a message via Yahoo to bboerner
Default Re: Result of Improper Door Installation
Do you look behind all rim insulation or just where doors are present up above?
Bill Boerner
STL Home Inspection Services LLC
Serving St. Louis/Surrounding
(314) 805-2137
office@stlhomeinspector.com
http://www.stlhomeinspector.com
Residential, Commercial, Radon, Termite, Lateral Sewer Scopes
Old 6/6/09, 7:20 PM
Mostly below doors, and areas where the insulation is discolored.
Old 6/6/09, 8:47 PM
William J. Decker's Avatar
Rule # 101: "Caulking is not flashing."
Nuff said.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 6/6/09, 10:02 PM
Bobby Hamilton's Avatar
Bobby Hamilton Bobby Hamilton is offline
Same thing here from a previous thread. I pull back the insulation, as much as I can. If you saw this post, you'll see why.(video shot is actually my own house that I'm repairing right now). The inspector (about 9 years ago, when I was doing construction and not inspecting) didn't look behind the insulation and the sill is rotted out. This guy is still in business touting his 30 years experience.
Bobby Hamilton
Bloodhound Home Inspection Services
Youngstown Home Inspection
Austintown Ohio Home Inspection
Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Old 6/6/09, 11:17 PM
rdimmerling rdimmerling is offline
It is good to check where you have decks too, I have seen problems with water intrusion from them not being flashed or improperly flashed.
Richie Dimmerling II, P.E., S.I.
Inspection Engineer
614.309.7552
Old 6/6/09, 11:30 PM
Joe Funderburk, CMI's Avatar
And porches!
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 6/7/09, 6:52 AM
Unfortunately, we have too many finished basements with drywall ceilings that conceal these problems. A moisture meter is most likely useless unless the water migrates to the drywall surface. I doubt if my infrared imager would detect abnormal conditions in most finished basements that have similar water intrusion issues, although I do scan the rim areas.
Old 6/7/09, 10:01 AM
This was a sliding door unit too!
Some people just don't know how to flash door units. Or build period.
Old 6/7/09, 12:18 PM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
Nuff said.
Exactly!
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 6/7/09, 2:30 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
No deck flashing
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 6/7/09, 2:40 PM
There wasn't any on this one either.
Old 6/7/09, 6:59 PM
Great images! Where are the local code inspectors? Marcel, can I borrow your deck ledger images?
Old 6/7/09, 7:54 PM
Be my guest John.
Old 6/11/09, 7:54 PM
Peter C. Russell's Avatar
I always use one of these to check the rim joist, makes it easier and it works great for opening the attic hatch.
De-rate? Due to improper seperation? rstewardson Electrical Inspections 4 3/24/09 11:43 AM
Improper engineering bclark Inspecting HVAC Systems 9 1/8/08 11:03 PM
Defects as described by Lawyers mcyr Miscellaneous Discussion for Inspectors 3 10/28/07 7:58 AM
Question about improper installation cbell1 Exterior Inspections 3 10/24/07 9:13 PM
