The past couple of inspections, I have come across a situation where the ridge beam is not a continuos length from the gable on one side of the house to the gable on the other side of the house. The ridge beam is in two sections just butted up against each other approx in the middle of the house. There are no supports under this joint to safely bring the two butted beams to the load bearing walls below.
The ridge beam is suppose to hold up the rafters. In these cases I feel that the rafters are holding up the ridge beams. The span is about 60 feet. Why would a framer not run a continuos length of a beam gable to gable? Thanks for your help, Rick Last edited by rmarton; 2/5/12 at 7:32 AM.. Reason: I ment ridge board guys. I read the other posts and I have a 4 on 12 pitch |
| Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I've never seen a 60' piece of lumber, never seen a 20'x30' sheet of plywood either.
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
OK Linas now be nice! A ridge is not needed in some cases at all when the roof has a proper pitch and the rafters oppose each other.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Rick
If the rafters are directly opposite each other than it's a ridge board not a ridge beam and it only aids in placing the rafters, no structural function. Many older houses were framed without a ridge board. If the rafters are NOT directly opposite then it is considered a ridge beam and should be designed to take the bending forces created by the offset rafters. |
Of course the rafters are holding up the ridge beam! Do you think it hangs up there in mid-air? Simply amazing!!....... again BTW: Did you know water runs down hill (sometimes)? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Here are pictures from InterNachi graphics to explain.
Randy,
Thanks for your clear answer. As for David, You sound like a nice tough guy I would like to meet. I would like to see your in the flesh (SAILOR) |
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Are you mad at Dave for pointing out how stupid your question was? How did you know Dave is a former Navy Seal?
Sorry, This influx of untrained inspectors gets on my nerves about every cycle of FNG's.
I really don't think anyone that does not know the basic "tension - torsion & shear" principles should be inspecting houses... Just my screwed up warped sense of expectation from self proclaimed experts. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
The rafters hold up the ridge board... not the ridge beam. The ridge beam will holdup the rafters.
Where there is a Will there is a Way! Will Misegades TREC# 10465 RedFish Home Inspections www.redfishinspections.com |
all right, quit being so damn picky!
too late !
Kevin or anyone That graphic shows a load bearing wall on the second floor. I thought trusses needed no intermediate support between exterior walls. |
| ridge board smaller than rafters | rwashington | Structural Inspections | 16 | 6/25/09 1:19 PM |
| Number of Nails connecting roof rafter to ridge board | arook | Structural Inspections | 16 | 4/26/09 4:17 PM |
| Ridge and rafter issues/shed dormer | Adam J. Deangelo | Structural Inspections | 1 | 5/16/08 3:30 PM |
| First to answer this question substantially correct wins a NACHI Beam. $109 value. | gromicko | Miscellaneous Discussion for Inspectors | 18 | 1/22/07 8:55 PM |
