Old 6/17/09, 6:59 PM
Michael R. Boyett's Avatar
Default Ridge board check
Another inspector asked for my opinion on a ridge board he had seen at an inspection today. The ridge board had a very visible 1/16" or less check or crack running 4-6' or so along the length of it. None of the rafters were separated, no sagging, no visible anomalies. He noted in the report the ridge board was cracked but functioning as intended and did not recommend any further actions. Seems reasonable to me, how about you? No photos available...it's pretty easy to envision . If corrective action was deemed to be required would a properly designed strong-tie or mending plate be appropriate? Kenton...what are your thoughts?
Find an InterNACHI certified Illinois Home Inspector (and anywhere else in North America)
Old 6/17/09, 7:04 PM
Default Re: Ridge board check
Without seeing it that sounds adequate.
Larry Kage, CMI
231 929 3525
Old 6/17/09, 10:31 PM
He did what I'd have done, Mike.
Look how many 100+ year-old homes are just fine with no ridge at all.
A ridge makes it easy to stand and stabilize the rafters during roof construction, and it provides a handy way to fasten them into place at the peak, with or without metal connectors and on or off layout.
Spometimes it also provides backing for boundry nailing at the ridge, but not when there's a continuous ridge vent, so it's not that crucial for that purpose.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 6/17/09, 10:33 PM
Sounds good...thanks for the quick reply. I'll pass this along to him.
Excellence in Inspections
Mike Boyett, TREC #7290
mikeb@capcityinspections.com
Capital City Inspections
Austin, Texas
(512) 577-2579
Old 6/18/09, 12:42 AM
dbelmont dbelmont is offline
Send a message via Yahoo to dbelmont
Please Note: dbelmont is a non-member guest and is in no way affiliated with InterNACHI or its members.
According to what I know ridge boards are not structural. They only help align the rafter pairs which are structural. So checks, cracks in a ridge board should not be at issue.
Different issue if your dealing with a structural ridge beam which is carrying roof load. Severe checking or cracking in that beam could effect ability to support load and will need an engineer to evaluate.
Old 6/18/09, 12:49 AM
I don't think checking is often a structural issue, even when it looks nasty. Cracking is a different story. Significant cracking would be failure.
(303) 717-8940
NH licensing prussell Legislation, Licensing & Legal Issues for Inspectors 12 5/21/08 5:40 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 10:24 AM
Segmented ridge board jskrypka Structural Inspections 2 3/31/08 6:15 PM
Read the message board rules: gromicko Miscellaneous Discussion for Inspectors 39 3/19/08 3:24 PM
Rafters separating from ridge board jmichalski Structural Inspections 8 3/13/06 9:52 PM
