Here are some pics from todays inspection. It isn't mold, at least it doesn't appear to be. Any suggestions?
Attachment 13856 Attachment 13857 "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com Last edited by nbhi; 7/8/08 at 8:42 AM.. |
The last time I observed something like this it was caused by numerous frost build-up on the underside of the roof sheathing. The frost and thaw cycles due to the temperature of the roof will cause moisture saturation and then it dries up leaving dark water marks on the wood plywood similar to a wood window sill that gets water on it occassionally. Rust on the nails in the roof sheathing is also an indicator of previous moisture. Ventilation seems or appears to be the problem, and heat loss is occurring at the juncture of the exterior wall and roof. Since there are no proper vents visible, it is posible that some heat loss is occurring in that area. The blown in fiberglass insulation is also depicting dicoloration due to moisture dropings and excessive heat in the attic space during the summer. I am sure you will have other opinions, but hope this helps. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Blackening on plywood is indicative of improper ventilation. There aren't any soffit vents installed. It needs ridge and sofit vents.
I'm seeing some delaminated sheathing also. |
Look at the attic air leakage points in the first two of the following references. These are only a few of the attic bypasses than you will actually find in houses.......trust me, I ran an insulation/airsealing company from 1980-1990 ; still do a few houses (10-15 per year now as a sideline; Was drilling a house until 7 PM last evening; no advertising used or needed...just turned down a $9,000 large house retrofit!!). I now try to get the homeowner to do the airsealing under my guidance since the labour/materials breakdown is around 85/15 - 90/10 and airsealing labour is straightforward and simple .....it's to know where and how to best airseal the bypasses. See: http://emergencypreparedness.cce.cor...ndensation.pdf http://www.danville-va.gov/upload/im.../chapter_1.pdf http://www.cmhc-schl.gc.ca/en/co/mah...gemare_001.cfm Last edited by Brian A. MacNeish; 8/12/07 at 11:36 AM.. |
I did an inspection and it was exactly like that.
Found an open 4 inch plumbing vent under the insulation. .. Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Good links Brian.
Thanks, makes for good reference. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Good points. Thanks guys.
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
Obviously a moisture issue with plausible sources already pointed out by Marcel, David, Brian and Russel. So if it's a moisture issue, why isn't it a mold issue? If those dark areas aren't mold colonies, what are they?
This looks like an intermittant moisture problem with mold colonies which only get a chance to grow when conditions are right for creating condensation on the underside of the sheathing. Find where moist air is leaking up from the living space and the mold fungi will go back to sleep. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Mould needs 5 conditions to grow: 1) a food source of which cellulose in wood, drywall paper is 2) spores (seeds) 3) cool to warm temps 4) moisture in terms of wet/damp materials or constant high RH over 70% 5) generally, dark conditions Remove any 1 of these conditions and mould will not grow. Sheathing may get wet/damp in the coldest parts of the winter but the temps are not conducive to mould growth. If the sheathing dries before temps get constantly in the range to allow growth, mould will not grow as the moisture condition is removed. I believe that this is the situation that causes the staining- moisture but no growth. |
| A little on the Commercial side of things. | mcyr | General Inspection Discussion | 457 | 8/1/09 10:50 AM |
| Cracked shingles | pwigle | Exterior Inspections | 54 | 4/23/09 11:52 PM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
