I'm looking through the NACHI Standards of Practice, and I don't see any reference to roof decking or roof structure. Am I missing it somehow? I do tend to inspect the underside of the roof decking and the roof structure (trusses, rafters) when I check the attic. But I don't really see any reference to that.
Certified Property Inspector
Home - Commercial - International Love my family. Do the best quality of work I can. Serve with compassion the orphan children of the Philippines. |
| Need a home inspection in Indiana? Check out InterNACHI's listing of Indiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Although quick to the point, E. should be what your looking for. The Texas SOP has more detail but gets to the same point.
2.1. Roof I. The inspector shall inspect from ground level or eaves:A. the roof covering; Fort Worth Home Inspector Dallas Home Inspector |
Ok, Tom, that helps. Thanks! Now my next question is this: When I read 2E in the standards, it's referring to the ground, or eaves, or accessible panels, etc. It doesn't quite seem to mention the attic space, which is to me the best place to look at roof structure. I'm not trying to be picky, I'm just trying to understand all of what the standards have to say about the attic space.
The roof structure and roof decking is an important inspection component. The Texas state standards requires: (g) Roof structure and attic. The inspector shall: (1) report: (A) the vantage point from which the attic space was inspected; (B) the presence of and approximate average depth of attic insulation and thickness of vertical insulation, when visible; and (C) evidence of water penetration; and (2) report as Deficient: (A)attic space that does not appear to be adequately ventilated; (B)deficiencies in installed framing members and decking; (C)deflections or depressions in the roof surface as related to the adverse performance of the framing and the roof deck; (D)missing insulation; (E) deficiencies in attic access ladder and access opening; and (F) deficiencies in attic ventilators. |
I like what the TX standards say about this. Maybe a bit too much since there are so many attics where you just can't see it all. But overall I like it. Thanks for the info!
2.3.D covers structural components but I agree, the word roof or attic needs to be added to the 2.3 heading. Maybe the problem is that some areas call attics crawlspaces. This is typically up north where they have basements instead of under floor crawlspaces.
2.3. Basement, Foundation & Crawlspace I. The inspector shall inspect: A. the basement; B. the foundation; C. the crawlspace; D. the visible structural components; B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
| Vegetation Roof Systems Educational by NRCA | mcyr | General Inspection Discussion | 2 | 10/14/08 5:49 PM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
| Avoiding Litigation Thread. | gromicko | Miscellaneous Discussion for Inspectors | 147 | 5/8/06 6:41 PM |
| Moss growing on roof | ecox1 | Exterior Inspections | 45 | 1/19/06 9:57 PM |
