Tell me... am I missing something or is this work a POS?
Scabbed on pieces, doubled up framing... this was built in 10/2005. I've thrown in some photos of the shingles as well... and they think new homes do not need to be inspected... ohhh for the hell of it check out where the panel is grounded to the water pipe... which is plastic.... </IMG></IMG></IMG> Jeff Campbell Campbell Property Inspections http://www.maineshomeinspector.com Pittston, Maine NACHI04013010 Last edited by jcampbell; 8/14/08 at 12:42 AM.. |
Jeff,
Built in a rural area?......unreal.... County building inspector, doubling as dog catcher when business is slow..... |
tneumann is a non-member guest and is in no way affiliated with InterNACHI or its members.
In my rural area..it is quite possible the inspector built it.
But look at all the money the builder saved. Unless he has to fix it.
"Do it once but do it right" Bill Bill Emelander Professional Edge Home Inspection Grand Rapids and all of West Michigan NACHI #03111914 www.proedgehi.com |
cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
hopefully the electrician was "bonding" the water pipe and not using it as "grounding"
I don't really see what the fuss is about. The added rafters and scab may habe been to make the roof sheathing breaks work. Two rafters are stronger than one. Minor gaps at the rafter top cuts. Undersized ridge, but I often see homes that have been standing for 100 years with no ridge at all. In many arreas the engineer would have required hangers rafter to ridge. Not clean framing but it looks structurally sound to me. Builder took low bid or it was framed by the homeowner. I wouldn't even mention it.
Roof- I see a ridge vent but no missing/damaged shingles. Maybe a little ice. Plastic ground eh? Well shoot, write that puppy up. I'm sure you did, Jeff. When I see low quality work I usually think low budget/ low quality. Not everyone has a lot of money. Kent |
Very good Jeff;
Too bad to think that this goes on in our neighborhood. Must have been Carpenters that applied for a job last week on my job and lasted four days. They can make more money doing work like this on their own than work for someone that knows what he is doing. Marcel |
I ran out of spots for photos... it is hard to see the roofing. The shingles are all lifted up towards the ridge... but throughout the roof there are spots of roofing tar...
the electrician got back to me and stated there is a ground outside to a rod... OK fine... (could only see the conduit but wanted to make sure)... The rafter framing is just plain sloppy... Keep in mind this is NEW construction Here are some additional photos of the roof... Last edited by jcampbell; 8/14/08 at 12:42 AM.. |
those pics of the shingles are much better, looks like pretty sloppy work, notice how high they are riding above tab, and you could see some nail pops on the first pic, that tar is probably from someone getting a little wild with the nail gun and not replacing their goof up, just slap some tar on those errant holes!
"If God was one of us, would he recommend a detailed analysis by a structural engineer for the world?" Michael S. Saxton http://www.duluthhomeinspections.com |
Would it be possible than for once, a Roofing Contractor followed the Roofing Manufactures instructions that are on most packages or bundles.
Installation of this product on a 6/12 pitch or greater requires dabs of roofing cement under the tabs in order to qualify for wind damage. They miscalculated the bottom of the tab. Marcel </IMG></IMG> |
Marcel is that true? I have to do some research then... I personally have not installed shingles on anything greater than 5/12...
thanks Jeff Campbell Campbell Property Inspections http://www.maineshomeinspector.com Pittston, Maine NACHI04013010 |
Jeff; I will get you the reference. Tried but the computers were off line, I will try tomorrow.
Marcel |
ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
I was going to say that having been a framer at one time in my life, I can recall having to scab on 2x4's so that the sheathing would work out. Put a tape measure to the spacing and I'd bet that the spacing is off. I never put roof trusses in place.....so it wasn't due to my intellectual frailty.
jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
| A little on the Commercial side of things. | mcyr | General Inspection Discussion | 457 | 8/1/09 11:50 AM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 1:21 AM |
| Roof framing questions? | badair | Structural Inspections | 7 | 2/22/07 8:03 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 2:19 AM |
