Old 4/11/11, 7:55 PM
Sean Fogarty's Avatar
Default Roof framing question
I commonly see many homes constructed with the ridge board the same size as the rafters and then the framers add a furring strip or 2x2 at the bottom to cover the left over gap at the bottom. Today's lacked this.
Should this have been installed?
Also the rafters were glued togeather crappy 2x4's or the left overs made into a larger board. How well do these function compared to a solid piece of lumber?
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/11/11, 8:34 PM
Jeffery L. Haynes Jeffery L. Haynes is online now
Default Re: Roof framing question
They typically do fine as long as they extend to the bottom cut of the rafter.......they simply help prevent the rafter from pulling away from the ridge board during uplift forces.
What I see as a more common issue is missing valley plates...... you have the bottom cut of the rafter simply sitting on plywood or osb.
Old 4/11/11, 8:50 PM
Thanks Jeffery, I figured as much. Most of the homes I look at over 3000 sf tend to have some unique framing practices and applications.
865-256-5397
Old 4/12/11, 1:55 AM
ctasker ctasker is offline
Please Note: ctasker is a non-member guest and is in no way affiliated with InterNACHI or its members.
The ridge board should be one size bigger than the common rafters to achieve full bearing,2x4 rafters =2x6 ridge board,should be collar ties 48 inch on center,upper third of rafter,unless they are not shown in the pic.
Old 4/13/11, 8:01 AM
Larry J. Michael Larry J. Michael is offline
This is correct, but I typically only write it up on new construction.
Greensboro Home Inspection
Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas.
greensboro-home-inspection.html
Raleigh Home Inspection
Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas.
Raleigh-home-inspection.html
BassRumors.com
Providing a blog, news, and forum dedicated to bass fishing.
Old 4/13/11, 8:29 AM
Jeffrey R. Jonas's Avatar
Why? What is your reasoning?
Old 4/13/11, 12:50 PM
Mark S. Tyson Mark S. Tyson is offline
[quote=sfogarty;770906]I commonly see many homes constructed with the ridge board the same size as the rafters and then the framers add a furring strip or 2x2 at the bottom to cover the left over gap at the bottom. Today's lacked this.
Also the rafters were glued togeather crappy 2x4's or the left overs made into a larger board. How well do these function compared to a solid piece of lumber?[/quot
Sean,
While the roof depicted in the pictures may be functioning fine I would disclaim in some manner in the report because at some point in time your buyer may become a seller and the new buyers inspector will probably call out the roof framing and the next thing you know they will want you to pay for an engineers report.
When rafters are joined by a ridge board the ridge board must be no less than 1" nominal thickness and not less in depth than the cut end of the rafter. As far as the 2 x 4 stacked because there is no span table at least that I'm aware of that addresses that condition it then would have to be an engineered design. Again not saying that it does not work just that we need too cover our behinds
Mark S. Tyson
M Tyson construction LLC
Tyson Home Inspections
Certified General Contractor #1516843
Florida Licensed Home Inspector #1824
Member N.A.C.H.I.
IAC2 certified
Member Florida Building Officials Association
http://www.TysonHomeInspections.com
Shooting to begin on comprehensive new roofing courses kshepard Inspection Education & Training 4 11/7/09 2:59 PM
Roof question mashburn Exterior Inspections 23 12/16/07 7:14 PM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 1:19 AM
Wood shake roof question jclark1 Exterior Inspections 4 9/11/06 9:23 PM
