What would be the correct roof span/size for a enclosed patio flat/low slope roof with snow load?
This is a home built in the 50's and the patio seemed to be built in the 70's. There was no sagging or deflection noted. These seemed to be about 24/25 inch on center 2 x 8 Thanks. |
| Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Depends on the thickness of the sheathing. Looks to be 24" so if no deflection, why raise the issue?
I did not raise an issue with this structure as there were no signs of any problems , I was just asking what the span and size requirments are?
I was looking at table 9 in the code check book on roof rafter span and was just curious. |
IRC Table R802.5.1(1), or subsequent tables depending on snow loads.
dquigley is a non-member guest and is in no way affiliated with InterNACHI or its members.
You also need to know the species of wood - spruce or southern yellow pine - big difference between the two
Most species used in residential construction are Pine, Spruce, Fir.
Floor Joist spacing is usually 16", 19.2" and 24" on center. Stud spacing is usually 16" and at times 24" on center. Rafter spacing is typically 16" for stick frame and 24" for trusses. The information that you did not provide us is the span of the enclosed porch. Your question should be..... I have a porch with a span of ___ feet with 2x8 rafters at 24" on center using ___________ (species of wood), what would be the minimum for a slope of less than 3/12 with a moderate to heavy snow load? At any rate, 2x8 rafters will typically span almost 14 ft. at 24" on center. Let me also say that you did not provide sufficient pictures to accurately assess you question......... the span of the deck may be 12 feet....yet the rafters may be going back another 4 foot up the roof to get the 3/12 (probably 2/12) pitch, unless the framer busted the load down with bracing then your true span in the above scenario would be 16 ft. If you want your question answered then you need to provide more info.... regard Jeff |
Thanks for the responses.
I am not sure of the wood type. I do not have the questions for your answers. Was just looking for some education. |
| Roof rafter question | dokeefe | Structural Inspections | 2 | 5/20/10 10:34 AM |
| Roof framing questions? | badair | Structural Inspections | 7 | 2/22/07 7:03 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
| Moss growing on roof | ecox1 | Exterior Inspections | 45 | 1/19/06 9:57 PM |
