I inspected a Bungalo ranch today that had a dormer on the left side of the home. The pics are from the right side of the unfinished attic. What I don't think is right is the rafter are only supported by the outside wall and knee wall! There is nothing holding them at the top(Ridge beam, hanger etc..) It was built over 20 years ago which means nothing, howerver would you recommend a second look??
Thanks in advance! Chris Christopher Rich A Closer Look Home Inspections, LLC 609-802-2001 www.ACloserLookHomeInspectionsNJ.com ACloserLookHomeInspections@comcast.net |
r u saying they just are hanging in the air... cannot tell from the picture... insulation holding them up? I see a lot of staining there too...
how did it look from the roof? outside? Jeff Campbell Campbell Property Inspections http://www.maineshomeinspector.com Pittston, Maine NACHI04013010 |
i am a stinkin membah!
so I was late renewing... now I have new number... login... blah blah blah... Jeff Campbell Campbell Property Inspections http://www.maineshomeinspector.com Pittston, Maine NACHI04013010 |
Hey Jcampbell....they just end at the insulation and have no bearing on anything. The exterior roof looked ok. Should there at least be hangers or support posts to transfer the load?
I would think so... it that the peak? in the second photo?
Yes it is.. The dormer studs run up the wall where the roof rafters terminate into nothing? Let me see if I can get you a pic of the outside.
Here is a pic of the outside. The right side of the home has the rafter's that have no support(other than knee wall).
I've seen plenty of roofs where the old rafters just meet at the peak and there is not ridge pole...
the rafter butt up against the dormer? not even nailed? into the studs for the dormer?
It looks unconventional... never seen anything like it... I would likely recommend further review... but again, i am not 100% sure what I am looking at... Jeff Campbell Campbell Property Inspections http://www.maineshomeinspector.com Pittston, Maine NACHI04013010 |
So even though they don't meet anything but the isnulation and wall studs(not secured to anything) it's ok?
I am guessing they are or at least should be nailed into the studs (side by each) and that is not necessarily conventional practice... review by a contractor may warrant adding hangers or even a ledger board for added stability...
The top ends of the rafters should definitely be attached to the new wall, which if I'm seeing it right, extends up past the rafter ends. Sometimes a horizontal 2X6 or similar can be nailed to the wall to catch the rafter ends.
It looks like the flashing is leaking there as well. Call for an evaluation by a qualified builder. |
exactly... a horizontal ledger board to catch the ends of the rafter... as well as toe nailed into the studs... cannot hurt to recommend further review...
yes i echo the staining... moisture content? active? old? probably prior to last roofing job, but worth flagging... Jeff Campbell Campbell Property Inspections http://www.maineshomeinspector.com Pittston, Maine NACHI04013010 |
Thanks guys.. I measured the stains and no moisture, roof was only 10yrs
old, house was 70yrs. Thought the same thing there should at least be a ledger board to secure these rafters. They were just floating above the insulation. Have a good night and thanks again!! Chris Christopher Rich A Closer Look Home Inspections, LLC 609-802-2001 www.ACloserLookHomeInspectionsNJ.com ACloserLookHomeInspections@comcast.net |
OMG, a piece of house just fell out of the sky and landed on the roof of that poor little house...but what a coincidence, it has the same siding as the house it fell on.
Rafters can cantilever, too, you know. Someone should check it...better a qualified design professional than a contractor. 2x8s cantilevering three feet? Might work, might not. Last edited by Richard A. Hetzel; 8/14/08 at 8:09 AM.. |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
