I have never seen this type of sheathing. It appears to be sheet rock laid on 1 X 3 lath, with some type of tar backed paper, on top of this is plywood. Any ideas? House is sixty plus.
I hope the photo works, my first at trying to send a photo. Thank you. |
Local jurisdiction mandated probably? I would check with the AHJ in your area. http://www.gypsum.org/pdf/GA-276-05.pdf Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Thanks! I never seen this type of sheathing in 32 thirty two years of firefighting.
dbucknavich is a non-member guest and is in no way affiliated with InterNACHI or its members.
So after reading that, is it a single family or multi?
BTW, home inspection must seem pretty relaxing for you. Are you ever tempted to take your ax to a wall? Do you have any ladder safety tips to pass on? John Kogel www.allsafehome.ca |
Single family!! Nothing better than the smell of smoke and the sound of breaking glass!!!
Always tie the ladder in!!!!!!!.
Mine would be to not use metal ladders ,and use proper ladder angle.
slide hands along rails, rather than hand by hand on rungs. Put ladder 3 rungs higher than the gutter and do not climb the ladder in front of the house in case you leave marks. |
Jeff |
I don't like the idea of sliding hands along the rails, I think that's a bad practice. Granted, holding side rails is how it's shown in the picture on the OSHA site, but my personal experience with OSHA and my opinion is that a few of their methods (like ladder climbing and nailing cleats for scaffolding to walls) are wrong.
If you grasp the rungs you can catch yourself if you slip, even with one hand. If you're holding onto a side rail, chances are you won't, you'll fall. To descend safely- I believe more accidents happen while descending- you don't release your grasp on the upper rung until you have a grasp on the next rung down. With 30 years as a carpenter, I've caught myself a number of times this way. Never had a serious fall. The safest way to climb or descend is to maintain three-point contact... you only lose contact with the ladder with one foot or one hand at a time. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
