A client is having a new roof installed and in the process will abandon the passive pancake vents currently in place and replace those with a ridge vent. Can the roof sheathing be cut out that contains the hole for the passive vent and replace that with a new piece of sheathing without a hole. Can that new piece of sheathing span from one rafter to the next or must it span more than two rafters?
Excellence in Inspections Mike Boyett, TREC #7290 mikeb@capcityinspections.com Capital City Inspections Austin, Texas (512) 577-2579 Company blog is: www.capcityinspections.com/blog |
| Find an InterNACHI certified Rhode Island Home Inspector (and anywhere else in North America) |
If its going to only span the area that the hole was in, it'll need supported underneath, otherwise your going to fall through when you step on it. 3/4 overlap on a rafter isn't going to hold the weight up.
Bobby Hamilton Bloodhound Home Inspection Services Youngstown Home Inspection Austintown Ohio Home Inspection Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Yeah, well after asking the question I did find that "OSB by Design by the Structural Board Association" does say that all panels must be continuous across 2 or more spans which would be 3 rafters.
A rectangular piece of sheathing is cut out slightly bigger than the hole to be patched and solid blocking is added at right angles to the rafters and nailed. Somewhat like lader framming that we see on overhangs. A new piece of sheathing is then nailed on all four sides and well supported. When it is a small hole like a vent, one slides a piece of furring through the hole and screws it through the sheathing on both sides and then a plug is set in and screwed to the furring underneath. Hope this helps. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Exactly, Marcel...have done it many times with no problems. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
OK, that seems to make the most sense even though it doesn't quite comply with the OSB Design Guide I referenced. The rest of the story is that the client (not my client btw but rather another local inspector's) is an 'engineer' of some persuasion and is adamant that the new sheathing span 3 or more rafters. The roofer was planning to use the blocking method but the client wouldn't hear of it. No big deal and not really an inspection issue...just another example of me and the other inspector wanting to know the best and/or most industry accepted practice in this case. Thanks.
In reality spanning 3 rafters is much stronger, but it ain't going to be done like that Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
A lot of the vent patches I see just have a piece of sheet metal nailed over the hole. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
Nothing to add. Marcel, as usual, got it right.
Helm Home Inspection David Helm, Owner/Inspector http//www.helmhomeinspections.com |
dbolduc is a non-member guest and is in no way affiliated with InterNACHI or its members.
There goes a couple more trade secrets.
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 7:31 AM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 1:35 PM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 1:21 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 2:19 AM |
