The house is probably over 70 years old. The sheathing was upgraded to plywood at some point in time. Another home inspector (also a licensed contractor) stated that the rafters should have been braced to hold the extra load. You can see that no bracing is present. From the ground, there were no sags.
What say you?
| Find an InterNACHI certified Missouri Home Inspector (and anywhere else in North America) |
Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
I always recommend old roof framing practices be "upgraded" even if no sagging is present due to snow loads. The new plywood on top you mentioned just adds more reason for bracing and brings it to a reasonable "repair" item versus just an "upgrade". This is a good example of issues that can be legally reported or not reported as deemed necessary by an inspector based on the exact conditions, rafter spans and overall opinion of that inspector.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
I don't like the way the rafters and ceiling joists connections are made. They stack and are not lapped for strength. It appears plywood gussets were added on one joint. And it also appears that the rafters bear on a cantilevered section of the ceiling joists (out over the soffit?). Suggestion: "Framing does not meet current framing standards/practices. Some modifications have been made already. Additional framing or reinforcement may be required. Seek advice from framing contractor and design professional." InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
I'd say even though it's not conventionally framed, and there is no apparent issues, you could have the framing braced-framed-altered but personally I do not see any logical reason at the time of this inspection.
If the framing concerns you, being 70 years old, and still holding strong, have a contractor do what ever he may think is necessary to bring the framing close or up to to current framing standards. Or get three free estimates, ideas-suggestions to upgrade the framing from licensed contractors before you close escrow. It does good pretty good for an old house Joe... If I was buying it I wouldn't loose any sleep over it. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
We had 18 inches here a few years ago, typically much less but it does snow about every year. Ice storms are common too. We also had a hurricane once, Hugo came through in 1989.
Every 10 years we get 6 inches that stays around about 3 days. There are exceptions, however.
I should add that this is a pre-listing inspection. Actually, it's a post listing inspection. One buyer already walked. Partly because the 1st inspector had nothing nice to say about the roof structure. (The inspection was aborted...no report from the 1st guy.)
So far..... but it may have limits or have hidden stress cracks now that could react with wind from another direction.
Since it's an inspection for a seller, this is what I came up with. Thanks Larry.
"The attic framing does not meet current framing standards or practices. Some modifications have been made which impose heavier loads than the original structure supported. Snow may add even more weight. While no sags were apparent, additional framing, bracing, or reinforcement may be required or prudent. We recommend that you seek advice from a licensed general contractor." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Especially a Pre-Listing Inspection...if it wasn't, I wouldn't make a big deal out of it, but since some other nit wit might...good comment..!! Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
I would have simply stated that the framing does not follow basic building principles, which it does not as one can see by looking at how several of the rafters were spliced. Being that the roof is not sagging (and if not signs of stress are showing on the exterior walls) I would simply recommend a licensed general contractor familiar with framing principles evaluate same. By stating the above you are not tied to code (which did not exist back then) yet are relieving yourself of liability and directing your client to get a more qualified opinion. regards Jeff |
| Please post questions about anything having to do with roofing | kshepard | Exterior Inspections | 165 | 6/17/09 11:47 AM |
| Roof Decks and their problems | wdecker | Miscellaneous Discussion for Inspectors | 4 | 4/29/09 8:26 PM |
| prevention of vermin entry | jrudyk | General Inspection Discussion | 3 | 1/18/09 6:17 AM |
| Moss growing on roof | ecox1 | Exterior Inspections | 45 | 1/19/06 9:57 PM |
