Hey Guys-
On this manufactured house they came back and build another roof on top of the current one. I didn't see any evidence of problems on the walls around the home, but I wondered about whether the original walls were designed to carry that much of a load. Just curious to see what you guys thought...thanks. Kenny Rigler Home Inspections Hays, KS 67601 785-656-0272 |
| Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
What Gerry says is typically correct.
Were you able to see, or did you get a picture, of the truss bearing points/area? I have seen a roof system on a manufactured home, designed by a SE, that was headed off above the top plates and the new roof system rested on that. That one looks pretty straight. How long ago was the roof added? InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
If it's a standard 2x4'' at 16" OC wall sitting on a concrete foundation, the extra roof load should be no problem. That wall supports 1+1/2 stories (second story floor plus attic 1/2 story) plus the roof in many 2+1/2 story houses with no problems. Up in Canada and the northern US, it also must carry wet snow loads plus the house!! May look much worse than it is! |
It requires calculations to determine if it's safe. Recommend a structural engineer.
Kenny
In theory this new roof could be added with out overloading the wall studs. The wall is still carrying the same live load just needs to carry the extra dead load of the new roof. Typically wall studs are spaced to accommodate the attachment of siding, gypsum boards, etc and have significant reserve strength for vertical loads. With that said the devil is in the details and the new roof connection points would have to be analyzed and in that process enough data would be available to check the load capacity of the walls. Whew.... that was the long answer. The short answer is the current owner should show proof he had sealed engineer plans and a certification from the engineer and/or the installer that the roof was constructed according to plan. Anything less would warrant a statement in your report to have a SE review. |
You're right, Randy!
No, I didn't get a good look or pic of the truss bearing points as there was pretty limited access. And no, I'm not sure how long ago it was added as I was the only one at the inspection...but I'll ask. This was a unique situation in that the wife, who ordered the inspection, was getting a divorce and keeping the house. I guess to re-work the mortgage the lenders wanted an inspection. Quote:
My redneck inlaws did that to their trailer and 20 years later its doing OK
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
| Shooting to begin on comprehensive new roofing courses | kshepard | Inspection Education & Training | 4 | 11/7/09 2:59 PM |
| Roof Decks and their problems | wdecker | Miscellaneous Discussion for Inspectors | 4 | 4/29/09 8:26 PM |
| Vegetation Roof Systems Educational by NRCA | mcyr | Miscellaneous Discussion for Inspectors | 0 | 10/14/08 4:11 PM |
| Moss growing on roof | ecox1 | Exterior Inspections | 45 | 1/19/06 9:57 PM |
