After inspecting this multi-level roof top deck with many issues, I would like to know if any information is available related to the amount of load placed on the roof structure. In my opinion, a typical residential roof was never designed to carry the dead and live loads associated with these large deck structures. There is no feasible method to even determine if the support posts are set directly on a roof rafter or truss. The amount of material weight bearing on the posts is considerable. I am certain this deck was constructed without permits. But, even when permits are obtained, is anyone considering the load factors?
| Find an InterNACHI certified Arkansas Home Inspector (and anywhere else in North America) |
I wouldn't spend anymore time on this.
Express your concerns about the shoddy work and recommend that structural engineer evaluate this construction method. I think we both know what will happen. P.S. All they have to do is add a hot tub to make the fiasco complete. He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
It looks like it isn't the only one!
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
The added "structure" creates problems all the way down to the footings, which were certainly not designed for this addition. A recommendation for a Structural Engineer is definitely warranted in this case.
The rafters must be sistered under the posts. Looks like everyone in the neighborhood is doing it! It must be OK then! Right? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
WTF!!!
Helm Home Inspection David Helm, Owner/Inspector http//www.helmhomeinspections.com |
The roof top decks are very common in the city. It is amazing that a collapse has not occured. We are requesting an evaluation by a licensed structural engineer. i added a few more images, note the angle cuts on the posts!
dbelmont is a non-member guest and is in no way affiliated with InterNACHI or its members.
Looks like typical hack job carpentry. Likely DIY or maybe a handyman.
At 60# sf live plus dead load about 10#sf call it 70# times about 36 (just guessing SF from pics) I make it about 2520# on that end post. That a nice point load for any roof. I concur that the call is definitely an engineer to evaluate and design a fix if it's needed. I'd call out the post connection as well since I think it's a safe call it's not engineered for the stresses. |
Redneck construction fer sure..... I have seen better decks on the top of RV's at Charlotte Motor Speedway.............dang!!!!
Richie Dimmerling II, P.E., S.I. Inspection Engineer 614.309.7552 |
That is a really ugly deck, supports included. Add the too-big handrails and the gaps the kids could fall through in the railings,,,,,
It's an accident looking for a place to happen. |
Well, I received a message from the real estate agent today. This deck was constructed with a city permit and final inspected!! Plus, to apply for a roof top deck permit, engineered drawings are required. I will never be convinced this deck was engineered or inspected.
What code has the city adopted? That deck is a lawsuit waiting to happen.
Kenton,
Baltimore City is supposed to follow the IBC 2006 codes. I suspect this may have been a drive by city inspection, but I do not understand why the permit was even issued without required engineered drawings. Problem that may occur, the clients could interpet the city approved inspection as acceptable, therefore making my inspection findings appear to be too alarming. Fortunately in this case, the clients are moving forward with a structural engineering evaluation. I will post the engineer findings when available. |
| A little on the Commercial side of things. | mcyr | General Inspection Discussion | 457 | 8/1/09 11:50 AM |
| Where do I put the Aquarium? | mcyr | Structural Inspections | 3 | 11/6/07 4:05 PM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 2:19 AM |
