I've made a few post already on this house I had yesterday, however, I wanted to see if I could get some sound advice on how to describe the concerns I have with the roof structure. Again, the house was built 1948 and later moved to this location. I don't have any specifics as to when it was moved there. In the photo looking across the roof to the chimney, you can see the obvious sagging in the roof. In the photo looking at the chimney from within the attic you can see a lot of patch work. Any inputs would be greatly appreciated. Please be patient with me as this is actually my first official inspection (other than the 4 mock-up ones that I had to do to become a member on this organizaton).
Regards, Steve |
| Find an InterNACHI certified New Mexico Home Inspector (and anywhere else in North America) |
Stephen,
From your sideways photo of the attic it appears that the roof sheathing is old cedar shake. Is that right? If so, it will give a deflected appearance to the composite 3-tab roof covering overly and you do need to disclose this to your client. The bracing appears suspect and the wood slats do appear excessively deflected also. John Onofrey Licensed Professional Inspector Houston Home Inspection Houston Home Inspector www.texasinspectors.net John Onofrey President, Grail Media, LLC "Effortless Email Marketing" www.homehintsenews.com 2007 INACHI Inventions and Innovations Award Winner Free! Inspector Email Marketing trial click here |
Yes, it is cedar shake beneath. However, wouldnt the construction using 2 X 4 rafters @ 16" on centers over a 28' span with the additional supports added be a concern? I'm attaching another photo from the opposite of that same roof that is adjacent to where that chimney was.
Regards, Steve |
Got it. Thanks for the help. I think I can take it from here.
Regards, Steve |
don't forget about the step flashing and counter flashing needed for the chimney.....otherwise you will be getting a call when it starts to leak.
Another fine job done by Hackers R Us. regards Jeff |
Thanks Jeff. I actually caught this one in my report already. Wow, what a way to start out. That is, inspecting a house that's 61 years old right out of the gate.
Regards, Steve |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Before You Start Repairing or Replacing Roof Finishes from CMHC | mkyriacou | Canadian Inspectors | 0 | 9/17/09 12:52 PM |
| New sagging roof decking waffer board | cceccarelli | Exterior Inspections | 9 | 2/20/07 9:16 PM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
