Old 6/11/06, 7:11 PM
sfalvey sfalvey is offline
Default Screw jack support?
Does anybody know if screw jack supports are allowed as permanent support structures. I would prefer to see the lally columns, but if screw jacks are allowed, so be it.
Thanks,
Scott
Old 6/11/06, 9:01 PM
Carla Horne's Avatar
Carla Horne Carla Horne is offline
Default Re: Screw jack support?
substandard, nonconforming should be replaced with cement filled steel column.
Hi Scott
Old 6/11/06, 9:51 PM
This might help. For your information.
http://www.octoberhome.com/articles/...ustcolumn.html#
Marcel
Old 6/12/06, 12:50 PM
kkatzmann kkatzmann is offline
If screw jacks are simply "temporary support structures", and they are installed in basically every new home in my home state of Iowa. Then how does the building code inspector allow an occupancy permit rather than a temporary occupancy permit? The only problem I've ever seen a city inspector have with them is they must be anchored down.
Old 6/12/06, 2:30 PM
lewens's Avatar
lewens lewens is offline
Send a message via AIM to lewens
Please Note: lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
common practice up here in the great white north,eh?
Larry
Old 6/12/06, 7:09 PM
Agreed; and anchored top and bottom, and also rated for the intended load requirements of the structure it is supporting.
Marcel
Subpanel Bonding Screw away Electrical Inspections 24 1/9/08 3:46 PM
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 4:05 PM
Heavy timber posts and support beam hziegenbein Structural Inspections 3 9/24/07 4:38 PM
Steel post question sspradling Structural Inspections 42 3/2/07 9:59 PM
Support post for Beam, is this right? mlong Structural Inspections 63 7/25/06 7:34 PM
