home built in 1949, has what looks like could be original screw type lolly columns. Does anyone have any take on calling out these columns? I know they arn't intended to be a perminate support today, but did that code exist in 1949?
| Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
You can make a recommendation regardless of what code may or may not have existed at the time the home was built. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Describe it what it is...temporary support. Regarding 1949 code, I'm willing to bet that post was not installed then, added much later to support a sagging floor or replace a rotted or termite damaged wood post.
http://www.octoberhome.com/articles/...ustcolumn.html Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
Temporary support.
Gary Oleski Home Inspections Home Inspections Connecticut Connecticut . 06610 NACHI04012833 CT#HOI.341 C M I
I write all these screw jacks up as...
Recommend replacing all temporary screw jacks with cement filled Lally Columns on footings. |
Lally columns have been around (1st generation) for over 100 years however for the most part they were designed to have concrete in same...... there are special lally columns which are designed to be permanent however the screw version is not one of them although many code officials accepted same.
You can find more info on what product is code compliant at deancolumn.com |
Why do you think they are "temporary" ??
Read Adjustable Steel Columns for inspectors.
When i inspected in Illinois they are used in new construction all the time. What is the problem.
House 2 Home LLC 503-602-1420 HomePros@House2HomeLLC.ORG Protecting Peace of Mind One House at a Time IAC2 Certified IR Certified A favorite place on Google Maps |
The manufacturer has printed on them that they are temporary supports not intended for use permanently. Inspecting Adjustable Steel Columns by Arlene Puentes InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Last edited by inxil; 4/5/10 at 9:10 AM.. Reason: Article content removed because of copyright violation |
Glad you dug that up Larry.
Seems we have a contradiction here. |
Larry, that article has so many errors in it, I don't know where to begin. Pure nonsense.
And furthermore, the fact that the IRC says they can't be less than 3 inches in diameter means that they recognize ones larger than 3 inches as acceptable, not unacceptable. I just passed the ICC Contractors Exam a couple weeks ago and one of the questions was whether adjustable steel columns had to be permanently attached at the bottom or top. If they have to be permanently attached, how could they be temporary components? Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 Last edited by gromicko; 1/22/10 at 2:43 AM.. |
Think about how a home is built. No one can pre-determine the exact height between the top of the post footer and the bottom of the beam flange... the jacks HAVE to be adjustable. Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 Last edited by gromicko; 1/22/10 at 11:12 AM.. |
Having actually handled/used both of these columns, it is easy for me to see what they are talking about but for those that need further help understanding the difference between "telescoping" adjustable columns and "one piece" adjustable columns please read and see pictures here:
http://www.octoberhome.com/articles/...ustcolumn.html InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Difference:
![]() ![]() ![]() For full article go here: http://www.octoberhome.com/articles/adjustcolumn/adjustcolumn.html InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
| Strong-DriveŽ SD Screw for Structural Connectors | jjonas | Structural Inspections | 4 | 12/23/09 5:04 PM |
| Bonding Screw | kmalone | Electrical Inspections | 25 | 4/6/08 6:16 PM |
| Subpanel Bonding Screw | away | Electrical Inspections | 24 | 1/9/08 2:46 PM |
| Steel post question | sspradling | Structural Inspections | 42 | 3/2/07 8:59 PM |
