View Poll Results: SE or no SE??
Yes SE 1 2.94%
No SE 33 97.06%
Voters: 34. You may not vote on this poll
Old 3/10/06, 3:26 PM
Peter Foxe Smothers's Avatar
Peter Foxe Smothers Peter Foxe Smothers is offline
Question SE or no SE That is the question
Would you recommend a structural engineer based on this crack? The separation of the brick at the mortar joint was about 3 feet long. No other signs of settling..all doors and windows opened and closed good, no inside cracks at all, all the old caulk joints are intact & not separated, all trim is snug with no separations.
Foxe Smothers ( Owner / Inspector )
Pelican State Inspection
Your Best Choice for Home Inspection in the Shreveport & Bossier City Area!
www.PelicanState.Net
www.ShreveportHomeInspector.net
www.BossierCityHomeInspector.net
foxe@pelicanstate.net
LSBHI #10399
Old 3/10/06, 3:36 PM
Ted Allen Ted Allen is offline
Default Re: SE or no SE That is the question
Does the crack get bigger past the tree? Any deflection?
Any steel in there anywere near the crack?
Do you tie your left shoe first?
OK, I got nothing.
Old 3/10/06, 3:56 PM
Brian E. Kelly's Avatar
Is that a tree in the picture?
Old 3/10/06, 4:30 PM
After a close up detailed inspection of the object in question, I am positive that it must be something that may or may not be organic in nature.
Old 3/10/06, 4:39 PM
Dale Duffy's Avatar
Very nice
Old 3/10/06, 5:53 PM
ckratzer ckratzer is offline
Please Note: ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Get rid of the tree.It appears to be creating enough pressure on the brick veneer to crack the mortar joints.
A lot of people don't believe that trees and vines can do such damage...but...they can.
Old 3/10/06, 6:46 PM
twheeler
Guest
Posts: n/a
Its Brick veneer. In most cases when brick veneer is cracked, it can be remedied by a mason/bricklayer. I vote for "no SE".
Old 3/11/06, 3:06 AM
They were bushes. Heres the reason I asked. I did the inspection. Noted it in the report to monitor for future movement. For whatever reason they sold the house 3 months later. The HI who did the inspection recommended they contact an SE. They called me. They called the SE and the SE said don't worry about it and I said told you so. Just wanted to see what you guys thought and if you would have recommended the SE.
THX!
LSBHI #10399
Sump Pit/Pump Question Joey D'Adamo Plumbing Inspections 4 11/26/08 1:04 PM
Interesting Question? jmckenna1 Miscellaneous Discussion for Inspectors 9 11/25/07 1:13 PM
WA State Legislative update hmiller Legislation, Licensing & Legal Issues for Inspectors 153 5/4/07 11:55 PM
Rule of Thumb A/C sizing question from Practice Exam gliebig Inspecting HVAC Systems 9 5/25/06 1:38 AM
