This hearth is supported by a single adjustable steel post in the basement... as well as the surrounding framing... I flagged it for review even though it has been there for 6 years and no signs of movement.... it just looked odd... but then again I've seen worse...
anyone with an opinion? or recommendation? Jeff Campbell Campbell Property Inspections http://www.maineshomeinspector.com Pittston, Maine NACHI04013010 |
Adjustable steel columns are or should be considered temporary supports. Would recommend structural engineer to review.
Hi. Jeff;
My biggest concern would be the screw jack post. Those are designed for temporary support and this one is picking up the load of the hearth concrete slab. If I am not mistaken, your third pic seems to indicate a sag in the joist. The post was positioned there most likely to supplement the single joist that are picking up the floor load from the header. Those floor joist should have been double if not triple depending on the span. I would refer to an SE on this one to get it evaluated. I also noticed you could hang clothes hangers on the electrical wiring and an open box. Couldn't resist Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
There was a lengthy discussion on on the BB recently about this topic.
The consensus was the telescoping posts (as shown in the pics) where for temporary use only but that non- telescoping where OK -if provided their own footing and -the post mfrs. instructions were followed to make it suitable for permanent use. |
thanks for confirming...
Marcel = wiring was written up as well... I think the photo may distort the sag more than it is, but either way it is written... the joists on either side of the hearth is doubled up... I've been writing up these "temp" posts for years... see them everyday almost... have a good day all... Jeff Campbell Campbell Property Inspections http://www.maineshomeinspector.com Pittston, Maine NACHI04013010 |
Also Jeff, is that a gas shut off and pipe going through the Masonry? That little yellow pipe. ! Marcel </IMG></IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
yes... that is a gas fireplace up above
I can email you the larger photo... its clearer... |
Does the big picture change to a double joist? ha. ha.
I believe you Jeff. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
it does... must be magic!
lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
Would you please explain this. These posts are commonly used around here as permanent posts and as far as I can find out are perfectly acceptable and to code standards. Now I realize that code is a minimum but I would be calling out every basement support system in the country just for this issue. What are you using to replace these posts? Larry |
Thank you Michael
That bit on Canada enlightened me. Larry |
Structures that fail are standing right up to the point that they collapse ... JMO ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
JMO Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
| Texas Atty. General Renders Opinion about Liability Insurance | bthompson1 | Legislation, Licensing & Legal Issues for Inspectors | 45 | 12/21/07 12:57 AM |
| New product I would love everyone's opinion on | Al G. Liminator | Inspecting HVAC Systems | 18 | 7/25/07 11:17 PM |
