Old 2/17/08, 2:08 PM
John Evans John Evans is offline
Default Securing Top Plate To Steel Support Beam
Does anyone have information regarding the required method for securing 2x6 top plates to steel I beams? Inspection this morning, the plates were not secured.;)
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Old 2/17/08, 3:32 PM
Unmoderated Guest
Default Re: Securing Top Plate To Steel Support Beam
They are either bolted or anchored with powder-actuated fasteners. If they are bolted, of course, you would have seen the bolts on the underside of the top flange, assuming the steel was an I-beam. If they were anchored with powder-actuated fasteners, they may not be visible from below, but if you could see the top of the wood plate, they some should have been visible..
Old 2/17/08, 3:36 PM
They are "secured" by some common nails driven into the sides of the top plate and bent over the edge of the beam!
Old 2/17/08, 3:40 PM
Unmoderated Guest
Uhhhh, no. You didn't say that. =)
Well, I guess you did. The two methods I described are the two commonly used methods. Bent nails, I don't believe, are listed as among the acceptable methods. Are you sure they were not just for hanging Christmas lights or something?? )
Old 2/17/08, 3:52 PM
I guess the nails kept the plate in place until the floor joists and upper floors provided enough weight to hold the plates in position. Probably won't move, unless there is a seismic event. Did call it out as improper, recommend repair by....................
Old 2/17/08, 5:49 PM
tlower's Avatar
tlower tlower is offline
The bent nails are for the original inspector to use to hang his/her jacket on while inspecting the rest of the home, But I guess it must have been a warm day.
Timothy Lower
Centerville, Ohio
Heavy timber posts and support beam hziegenbein Structural Inspections 4 9/24/07 8:22 PM
Steel post question sspradling Structural Inspections 42 3/2/07 8:59 PM
Steel beam lateral support Mark Ellison Structural Inspections 10 1/16/07 10:40 PM
Support post for Beam, is this right? mlong Structural Inspections 74 7/25/06 7:47 PM
Steel beam bearing 1 1/2" scosta Structural Inspections 17 6/12/06 9:01 PM
