Basement waterproofing, corner… an interior system was previously installed $$
You are getting lied to, misled, ripped off folks, yep.
See the EXTERIOR vertical corner crack?
See the EXTERIOR step crack?
See the other exterior openings?
Those are were water, salts enter a block wall and then, most often, that water will be seen inside a basement at your feet, at-along the cover, the bottom of the basement wall/floor, yep.
1:45—2:10 Openings where water gets UNDER a garage.
No interior system or sump pump seals/waterproofs any of these exterior cracks and other openings, nope.
Same house, short close-up video of the exterior cracks and other openings
:05—:15 ‘exterior’ corner crack
:15–:25 ‘exterior’ step crack, see scrapers in crack? Huh?
:30–:45 gaps etc where water goes under garage
Now this next video is INSIDE the same basement…
When looking at the inside of basement wall, do you see a vertical corner crack?
Do you see a step crack?
Can you see the other exterior openings from inside? Nope.
BUTT… they sure as shtt exist on the outside eh.
So, many have NOT identified the existing defects in many basement walls because they erroneously assumed they knew enough/all of this subject, wrong!!! You fk’d up, BIG time.
The question now is, will you admit it? Huh?
Bye bye now.
