Go Back   InterNACHI Message Board > Specific Inspection Topics > Structural
Structural Contains discussions about the structural portion of a home inspection. This includes foundations, framing, et cetera.
Old 12/3/08, 11:28 PM
Jonathan N. Leahy Jonathan N. Leahy is offline
Default Seen in a Concrete Foundation
On a townhome I inspected today, I saw the following in the concrete foundation on the exterior. Unfortunately, the other side of this arrangement on the interior portion of the basement was concealed behind finishes. I did not see evidence of bracing in the rest of the basement.
Any thoughts on what the purpose of the exposed bolts/screws are would be greatly appreciated.
Thanks
Jonathan
Jonathan N. Leahy
President
A Rock Solid Home Inspection, LLC.
www.arocksolidhome.com
303-718-7779
US EPA Certified Asbestos Building Inspector
State of Colorado Asbestos Building Inspector
Residential Home Inspections, Asbestos Inspections, Radon, Mold Inspections
Old 12/3/08, 11:35 PM
Michael R. Boyett's Avatar
Default Re: Seen in a Concrete Foundation
I'd say that was a piece of angle iron bolted to the foundation as a brick ledge for the brick veneer above it.
Excellence in Inspections
Mike Boyett, TREC #7290
Capital City Inspections
Austin, Texas
Old 12/4/08, 12:21 AM
Yes, it looks like it is spanning the opening below the metal grillwork.
Larry Kage
231 929 3525
Professional Inspector and Infrared Thermographer serving the Traverse City, Michigan area and beyond.
ITC/FLIR CERTIFIED BUILDING SCIENCES THERMOGRAPHER
ITC/FLIR CERTIFIED LEVEL 1 THERMOGRAPHER
Old 12/4/08, 8:52 AM
Looks like the steel angle is bolted through to another angle inside, and it may be that this opening was added after the original construction. No one in their right mind would install a shelf angle backwards in new construction. It looks like a retrofit lintel, not a shelf angle.
Old 12/4/08, 1:22 PM
W. Michael Chris's Avatar
W. Michael Chris W. Michael Chris is offline
Would agree with Richard . . . what's behind the plywood? . . . anything seen on the interior the plywood covers?
Mike Chris, Santa Clara, Utah
NACHI: #05051385
HouseNspect@gmail.com
www.housenspect.com
activerain
"A man's home is his castle . . . until the queen arrives."
Old 12/4/08, 1:50 PM
The plywood is actually a boarded up egress window. The other side of the bolts or the metal was not visible on the interior in the basement at the time of the inspection.
Thanks
Jonathan
Jonathan N. Leahy
President
303-718-7779
Old 12/4/08, 10:41 PM
Thank you all for your helpful comments and discussion on this one!
Jonathan
Jonathan N. Leahy
President
303-718-7779
Old 12/5/08, 7:24 PM
So, how'd you end up with this? Did you call it a brick ledge/shelf angle or lintel? Whatever, to me it is to support the bricks above it and I suspect has no counter-part on the other side of the foundation. I bet the studs are epoxied or otherwise anchored into the foundation.
Austin, Texas
Old 12/5/08, 11:34 PM
Andrew Cox Andrew Cox is offline
Do the ends of those bolts hang over the metal grate, and won't they be in the way if anyone comes out that window and trys to push the grate up?
Andy Cox
http://www.CoxInspections.com
Kissimmee, FL
You’re Your Own Job Security.
Old 12/8/08, 2:04 PM
The metal bolts did extend along the front of the subject property at regularly spaced intervals. The bolts had a very minimal, if any, impact on exit from the egress window. Based on no expression of the metal ledge piece on the interior of the property, it looks like it is a ledge for the brick.
Thanks again all.
Jonathan
Jonathan N. Leahy
President
303-718-7779
Old 12/8/08, 2:06 PM
ckratzer ckratzer is offline
Please Note: ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree.
It looks like either someone mis-read the foundation plans and didn't pour the foundation wall(s) wide enough for brick.OR brick was an after thought and the prob. was remedied with angle iron.
Options in selecting materials for basement construction wdevries Canadian Inspectors 2 8/4/08 1:30 PM
Moisture in slabs mcyr Structural 7 8/20/07 7:33 PM
bbbb mcyr Structural 1 8/19/07 10:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
Common Defects List by Age of House trausch Education 10 6/12/06 4:52 AM
Copyright © International Association of Certified Home Inspectors, Inc. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
