12-year old home subject to high wind loads. I called this out as a wind-related stress crack. Crack is at the peak of the living room
I'm with John on this.
Without a lot more evidence, I am going with insignificant crack. Jeffrey Wortham ANS Inspections, Inc. www.ansinspections.com 630.276.8440 638 Langford Drive Bolingbrook, IL 60440 NACHI ID:04050181 |
Hi John,
The wind blows over 100 MPH out there sometimes. Because it's an area where two roof intersect, they'll move at different rates in response to high winds. My guess. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
John Springstead Home Inspections of USA 1752 N.E. Torch Lake Dr. Central Lake, MI 49622 1-231-544-8016 office 1-231-544-6001 fax www.homeinspectionsusa.us |
I wrote...
"A crack at the peak of the Living Room appears to be the result of limited framing movement caused by high winds. I would not consider this a structural concern." Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Sounds good Kenton, but I'll play devils advocate. If its not structural, "can I fix it and it won't come back again?" That's the kind of question I always seem to get.
I quite often suggest repairs and monitoring to determine whether movement is ongoing or completed. John Springstead Home Inspections of USA 1752 N.E. Torch Lake Dr. Central Lake, MI 49622 1-231-544-8016 office 1-231-544-6001 fax www.homeinspectionsusa.us |
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Kenton, what would possibly make you "guess" wind caused that minor crack?
They're going to fix some cracked drywall seams anyway, and may fix this crack, but I think it'll come back.
I have done it many times like that at a peak similar to this. "Slip Sheet".....!! Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
I once saw wind not far from here rip 3 sheets of plywood from a stack nailed together, flip them up against a 3'x6' window, and then blow them through the window.
So when they ask me what caused the crack, I tell them I don't know but it could be the wind. It wasn't settlement, it's in the center of a roof truss. Maybe it was Santa Clause up there. I'm open to suggestions. It's the roof section to the far right in this photo. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Well I blieve you guys are right. The client pointed it out to me, but I told him at the time that it wasn't serious. In fact, I think I'll take that out right now. Sheet metal tricks's a good one, Dale.
I would say Kenton is correct,, wind stress, minor.
| Attic Temperatures Can Pose Serious Risks | jtedesco1 | Interior Inspections | 4 | 4/2/06 10:17 AM |
