Old 3/19/11, 2:54 PM
omuro omuro is offline
Default Is this severe?
Hello Everyone,
I inspected a potential condo for my friends yesterday. It is on the third floor. In the middle of my inspection I noticed the hallway was slanted to one side about an inch and a half to the other side and on the other side of the wall the kitchen was slanted toward the hallway. When I went into the basement the center brick wall that ran half way through the basement was sort of collapsed underneath the same general area. The building is 101 years old. The door and door jams were not affected but there was an active crack on the entry way to the dining area. I should say when I pushed on the brick wall the bricks moved back as much as I pushed. (About 3/4) of an inch. Can I still write this off as it being ok? My friends are really excited and I don't want to alarm them. The pictures are from both sides of the wall and the close up is to show light is coming through in a few spots.
Any help would be appreciated,
Ozzy
severe-dsc02873.jpg   severe-dsc02866.jpg   severe-dsc02868.jpg   severe-dsc02864.jpg   severe-dsc02856.jpg
Need a home inspection in Washington? Check out InterNACHI's listing of Washington certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/19/11, 3:28 PM
James E. Braun, CMI's Avatar
Default Re: Is this severe?
When you can move a load-bearing wall with your hands, that is severe.
Old 3/19/11, 4:43 PM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is offline
What harm can their be in stating "the load bearing wall appears to have been compromised in its structural integrity, to be sure of the severity have this evaluated and obtain an estimated cost to cure by a structural engineer.
When it comes time to sell the property I am sure this will come up once again when YOU are the seller. It would be prudent to have the information of its structural integrity from a the proper individual.
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Donate here:
or send checks to the
Fl Home and Insurance Inspector Chapter
1103 W Hibiscus Blvd Ste 311
Melbourne, Fl 32901
Old 3/19/11, 4:44 PM
Randy L. Mayo, PE's Avatar
Randy L. Mayo, PE Randy L. Mayo, PE is offline
By your description I would say its a major concern that warrants temporary shoring until a more in-depth assessment can be made.
Randy Mayo, P.E.
573-201-8162
www.rlmengineers.com
Old 3/19/11, 5:02 PM
Marc-Andre Beauchemin's Avatar
Marc-Andre Beauchemin Marc-Andre Beauchemin is offline
Ozzy,
What caused the brik veneer to crumble?
Did someone throw logs at this wall?
Evidently a non qualified and non experienced brick layer redid the mortar pointing job as well as he could.
The wall is croked but with the pictures you included one would have to be drunk to see it straight.
I don't see any sign of danger.
Thank you for sharing though,
Beauchemin, Marc-Andre
BMAinspection.com
Brossard, Quebec, Canada
Old 3/19/11, 5:08 PM
Jeffrey R. Jonas's Avatar
Two Questions...
1) Do you like your friends?
2) Do you intend for the friendship to continue in the future?
One statement:
1) I would refuse to let any of my friends make that purchase without a (competant) SE's report. If they make that purchase without heeding my advice, well, that just goes to show what kind of friendship we had! I certainly wouldn't want to be around for the aftermath of that potential nightmarish scenario.
Old 3/19/11, 5:09 PM
Tom Leahy Tom Leahy is offline
Originally Posted by omuro View Post
When I went into the basement the center brick wall that ran half way through the basement was sort of collapsed underneath the same general area. Can I still write this off as it being ok? My friends are really excited and I don't want to alarm them.
This confuses me!! You seem to know there is a structural issue and you don't want to alarm your friends because they love this place?
Fort Worth Home Inspector
Dallas Home Inspector
Old 3/19/11, 5:24 PM
Have it evaluated by a qualified contractor and if someone tried to remove the wall, I believe it could be a support wall.
Just saying!
Brossard , Quebec, Canada
Old 3/20/11, 8:18 PM
Gale Morrisn Gale Morrisn is offline
Please Note: Gale Morrisn is a non-member guest and is in no way affiliated with InterNACHI or its members.
Ozzy,
I work for a company that specializes in foundation repair. It's a network with more than 50 dealers across the USA and Canada.
Boy does this wall look like a retaining wall of some sort, along the perimeter and touching soil. I see signs of water damage.
OK, so say it's really a wall running along the middle, with basement on both sides. A builder would not use heavy brick to build this wall unless it was meant to bear load. Otherwise, the builder would have used cheaper, faster wood to build the wall, or they would have made no wall at all. It is a load-bearing part of the structure.
_All_ load-bearing parts of a structure are important, and if they're failing, then there is a structural issue. WHile the outer walls of this may be fine, and the foundation is not the issue itself, the building is showing signs of sinking in the middle, which is what's manifesting itself upstairs.
Eventually, this sag will lead to cracked walls, jamming doors, and the floors sinking further. The damage to the value of the home will eventually be extremely high, more than $20,000. It's unfortunate that they're so excited, but I'd let them know what they're getting themselves in to.
~Concrete Treat: Concrete Sealer
Revolutionize Your Construction.
Old 3/20/11, 11:25 PM
Robert Ernst Robert Ernst is online now
Call it as you see it. Your not an expert in 100 year old brickwork. Let someone who is come in and do the evaluation. You friend can ask the seller to make the repairs, money in escrow for him to make the repairs or ask for a reduction in price, walk, or what ever but that's between him and his agent. If the wall looks this bad it should have been in the disclosure anyways and if it wasn't they are going to have to disclose it now. It will help your friend to know of this issue. Not saying anything and allowing him to buy it and then have a structural failure on that wall would be very bad for both of you. I'll have to admit that this question even being asked is a bit scary.
Old 3/21/11, 12:29 AM
Bob Elliott's Avatar
Not enough information in that picture.
Where are the I beam(s) posts,footings,joists,etc?
The slope in the hall may be from old wood in the floor joists above the second floor ceiling and only removing a portion of the sub-floor will help determine that.
The brick movement is ongoing for a very long time as the tucpointing is not new or crumbled all that bad as compared to the movement I see.
Only a foundation contractor and a carpenter can fix those issues.
Old 3/21/11, 8:46 AM
Joe Funderburk, CMI's Avatar
There's a white stick bracing the wall. Looks OK to me.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 3/21/11, 8:49 AM
Linas Dapkus's Avatar
Linas Dapkus Linas Dapkus is offline
Sounds like he'll do good with the local realtors.
Old 4/8/11, 12:48 PM
wgibbs's Avatar
wgibbs wgibbs is offline
Just came across this while looking through the history here....All I can say is, WOW!!!
Old 4/9/11, 9:51 AM
ctasker ctasker is offline
Please Note: ctasker is a non-member guest and is in no way affiliated with InterNACHI or its members.
A real estate agent would call this a character wall,100 year old houses did not employ brick veneer as a practice,it is probably load bearing ,save your friendship,call it.
New post on RealMatcher: Preparing for Severe Winter Weather inxil InterNACHI & RealMatcher Blogs 0 12/22/10 5:06 PM
How severe might the consequences be? kweiss Inspecting HVAC Systems 2 11/3/10 8:46 PM
Searching for a home with a severe roof rat problem. gromicko Miscellaneous Discussion for Inspectors 5 7/20/07 10:59 PM
A house with a severe roof rat problem. (posted by William Earl ) AskNACHI.org AskNACHI.org Inspection Questions Forum 0 7/20/07 6:31 PM
