Old 9/11/07, 7:26 PM
jweinberg's Avatar
jweinberg jweinberg is offline
Please Note: jweinberg is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default sills strapped vs bolted to perimeter foundation
34 year old house.
poured concrete perimeter foundation
Grade beam running down middle of floor with embedded anchor bolts that are attached to the floor structure. See first picture
HOWEVER.... the sill is merely strapped to the perimeter foundation (see other pictures) Looks like the straps are embedded in the foundation wall and then nailed to the sill. They appear to be in the proper locations where you would normally see anchor bolts.
QUESTION: Are these strap sufficient to lieu of the normal anchor bolts or not?
sills-strapped-vs-bolted-perimeter-foundation-img_0137.jpg   sills-strapped-vs-bolted-perimeter-foundation-img_0153.jpg   sills-strapped-vs-bolted-perimeter-foundation-img_0154.jpg
Old 9/11/07, 7:47 PM
Default Re: sills strapped vs bolted to perimeter foundation
Typically, yes.
One example: http://www.westernforms.com/product.aspx?lng=en&ID=32
Larry Kage, CMI
231 929 3525
Old 9/11/07, 7:53 PM
tdietrich1's Avatar
This might help:
http://www.nachi.org/forum/f23/metal-straps-instead-anchor-bolts-slab-foundation-19453/
tom
Old 9/12/07, 2:29 PM
Robert J. OConnor's Avatar
Note that plate straps typically need to be spaced closer together than anchor bolts.
JMO
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
IAC2 In new residential construction mcyr IAC2 Indoor Air Forum 0 10/9/07 6:45 PM
Nachi, The Foundation and Estill County Ky psabados Charitable Organizations 2 11/14/06 5:53 AM
Draw inspection " Foundation electrical" question lgongre Electrical Inspections 8 10/29/06 1:26 PM
