Rear porch construction was conventianal framing. Low sloped roof rafters sistered to the trusses as seen in the photo. Cape cod style home.
Obviously the county let it pass, home built in 95. No signs of issues but what would be any concerns? Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
| Need a home inspection in Idaho? Check out InterNACHI's listing of Idaho certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I wouldn't call that "sistering."
Often, roof framing will include a combination of engineered trusses and conventional framing. Without more of a view, it's difficult to see if there are any obvious deficiencies. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
what would you call it?? Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Sean
I would say part of the front porch roof framework is attached to the main truss. Technically you would have to get the engineer from the original truss manufacturer to sign off on attaching anything to the truss. I don't know the geometry of the roof system or the loads but this additional load to the truss could cause the roof or ceiling to sag in that area. |
Jeffrey is right this should not be called Sistering.
Don't forget that there is very little weight on that porch. This is not an engineer problem unless the weight was bearing on the roof joist attached which it is not according to the picture. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
It looks like additional truss members were added in the field, between the upper and lower truss cords, below the attached rafter.
![]() Improper framing at it's best. Note the vertical chords that were added to the truss and with the side attachment of the stick built rafters, it is all transferring the weight load to the bottom chord and top chord of the truss. Hope there is never a big snow load. The lower slope addition should have been overlayed on top of the sheathing of the original roof to distribute the weight more evenly upon the truss diaphragm. That would be similar to a dormer somewhat. In either case, it is clear to me that this construction was never part of the original truss design as Randy mentioned. Although this makeshift framing may last for years, it is not the standard framing practice and would is unorthodox in methods that could impair the original design capacities of the trusses of the original build at one point in the future. Recommend a SE or Architect to evaluate. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
The front porch was built into the trusses. The back part was not. They just added the framework to the existing truss structure. Fortunately there was little load due to the fact it was only a basic covering. I passed the ball over to someone else. Let them decide. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
oddly enough the one beside it did not have any additional bracing except for the one sad little brace the rest had. . The buyers agent was also a general contractor. She (yes a woman) should have some people that can look at it to provide further info. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Funny how one picture can tell you a million things more than general comment.
I stand corrected after looking at the second picture. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
| trusses in garage | Marlys Gwaltney | Structural Inspections | 5 | 11/14/08 12:06 AM |
| cut floor joice | John E. Gibson, #2 | General Inspection Discussion | 16 | 9/25/08 9:45 PM |
