Old 1/29/09, 8:52 AM
Joe Funderburk, CMI's Avatar
Default Slab efflorescence
What would you say? The house is on a slab. The grade slopes toward the house at the right side and away from the house at the left side. Some efflorescence on the right side and its heavy on the left side (where the grade slopes away from the house).
No moisture problems inside.
Efflorescence and spalling coating. Is this more than cosmetic? How can you get a coating to stick to this surface?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 2/1/09, 1:34 PM
lfoster's Avatar
lfoster lfoster is offline
Default Re: Slab efflorescence
Would the house be sitting on a concrete block pier wall ? Moisture holding inside the crawl space?
No leaks inside the home ?
Old 2/1/09, 1:45 PM
Dale Duffy's Avatar
Attachment 26527 Attachment 26528
They are not going to get anything to stick to the blocks as long as they are sucking up moisture.
Old 2/1/09, 5:35 PM
gbeaumont's Avatar
To follow on from Dale's comment:
........... the're not going to stop sucking up moisture until the level of the grade is below the level of the lowest block, it looks like you've a couple of inches burried on both sides.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 2/2/09, 1:35 PM
Linda, it's a slab. No crawl space.
I just thought it was unusual that the left side of the home, where the water grade slopes well, was worse than the right side where the grade slopes toward the home.
Theodore Roosevelt
Joe Funderburk, CMI
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
Do you call out efflorvesence gbrasseur Miscellaneous Discussion for Inspectors 10 4/13/07 12:51 AM
supply in slab or walls? jeubank Plumbing Inspections 1 7/8/06 10:36 AM
