The slab on this home has been beaten out for some reason at the slab edge. How should it be repaired or can it be? The plumber said that the plumbing was put in the wrong place and had to be moved and they would repair the concrete. I am curious how any repair could be made
No problem adding some good grade concrete there. The missing stud may need more looking into.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Thanks Bruce
simple concrete mix, and some fancy trouling would do it. the cut 2x should be fixed with a couple cripple studs and a small header to deflect the load around the plumbing.
I often find junk like that.
"Damaged for installation of utilities." NACHI 2005 U.S. Member of the Year
It would have been prudent to have had these plumbing pipes centered in the 2x4 wall and have had the concrete slab poured and finished around them and round bored holes through the plate. Then the studs could have been placed where they belong for the wall finishes.
Hopefully protector plates will be added and crippled studs added to span this opening. Because of all this piping, it weakened the slab enough for it to have cracked as it did. Is that sole plate Pressure treated and anchored with galvanized anchor bolts? Sloppy work. Marcel |
Weekend Warriors with Masters of all Trades in progress.
Marcel |
| Moisture in slabs | mcyr | Structural Inspections | 7 | 8/20/07 8:33 PM |
| bbbb | mcyr | Structural Inspections | 1 | 8/19/07 11:26 PM |
| Moisture control for slab on grade in protecting floor finishes | mcyr | General Inspection Discussion | 2 | 8/13/07 8:53 PM |
| Wood floor framing over a slab | gbrainerd | Structural Inspections | 9 | 8/10/07 10:39 AM |
| supply in slab or walls? | jeubank | Plumbing Inspections | 1 | 7/8/06 11:36 AM |
