New construction, well about a year old but still new. Hillside construction. So half the crawl space is a true crawl space, hand and knees. The other half is cut into the hillside, about 8 feet lower.
This is the only beam, in the middle of the house running from one end to the other. A total of 9 posts, 5 on the poured concrete in the dug out areas and 4 placed in between those in the rounds. The cut is about 7-8 feet high and along the full length of the beam, about a foot away from the edge of the poured rounds. So what would you say? Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
| Find an InterNACHI certified Hawaii Home Inspector (and anywhere else in North America) |
The angle of repose is typically 45 degrees and that doesn't even get close. I'd call it out. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Call it out.
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
You described that to me yesterday Steve, and that's even worse than I imagined. What were they thinking?
Needs an Engineered fix.
Where the slope is steeper than one unit vertical in one unit horizontal the required set back shall be measured on an imaginary plane 45 degrees to the horizontal, projected upward from the toe of the slope. now in english if the cut is 7' the set back would need to be 9.89' Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
All in addition to serious moisture issues by looking at the floor insulation condition.
I had one like that last month. I referred it to a SE, and it was not anywhere near this bad.
Im am just finishing up a root cellar.......I only dug about 4 feet deep and it was engineered................and yes; rule of thumb is a 1:1 ratio or 45 degrees as previously mentioned.......again that also have to do with the compaction rating of the soil.
regards |
Update on this item. Talked to the AHJ who looked up some information on this property. Over a year old, does not have CO yet. According to the AHJ, the builder states he has documentation with engineers stamp for the current configuration. AHJ further states that until they get that documentation and perform their final inspection, nothing will be signed off. If the documentation is not forthcoming or does not meet standards, a retaining wall will be required.
Should be interesting paperwork from the engineer. Can't wait to see it. Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I've seen homes that are 30+ years, and the insulation in the crawlspace looks awesome. |
