Hip style roof added onto the side of the home for garage addition. Rafters split down the middle.
For some odd reason they also took the corner beams and cut them in half lenght ways as well about half way up. No obvious problems were noted but why split the rafters? Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
| Need a home inspection in Louisiana? Check out InterNACHI's listing of Louisiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Bueller, Bueller??
Wow, you guys are on the ball tonight. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Just in from working all day myself...
I'm not sure I see what you're referring to. What is the actual dimension of the rafter? IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I'm not sure either. The spacing between the rafters seems excessive.
774 Manor Road Staten Island, NY 10314 718-514-3393 |
Do you know if it was a permitted addition?
I tend to think not. What was the approx. length of the rafters? I do not see any advantage to framing like that, unless they thought they were stiffening the middle of the span. But that would have been better done with blocking. Did the rest of the work look like the 3 Stooges did it with short-cuts? Pete Campbell pete4545@comcast.net http://www.PortStLucieInspections.com http://www.ChooseGI.com http://ifwemissitwewillfixit.com Inspecting Fort Pierce, St. Lucie Village, Lakewood Park, Vero Beach, Indian River Shores, Sebastian, Fellsmere, Fort Drum, Okeechobee, Jensen Beach, Stuart, Palm City, Hobe Sound and Indiantown, Florida. |
Ohhhhhhh. The rafters don't run the full length down to the plate. Is that what you are referring to?
Jeff answered it. Barry did also. It has to do with length from top to bottom. They were split half way down and supported. The roof was stable but still want to CYA.
It looks like they hacked out part of the hip rafter to install the upright support and then continued with a hip rafter that is too small. Also, there are not adequate connections made at the rafter and beam joints. And the beam appears too small. It is a bastard hip for sure. I'd not want a heavy snow load or large inspector up there.
My jurisdiction would require hangers, but I don't think those are available in TN
I noted it and suggested them have it further investigated if they choose to. I said it seemed to be functioning but not a common building practice.
How do they continually come up with ways to do this stuff is beyond me. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
"Unorthodox attic framing methods." Refer to a PE.
Some good illustrations here: http://www.nachi.org/gallery/framing/framing.
Absolutely unnecessary. Conventional framing does not require engineering.
Dimensional lumber has already been "engineered" to carry specific loads based on size, spacing and span. Any qualified framing contractor can make necessary modifications and/or corrections. Only engineered systems (such as trusses) require evaluation, design and approval from a PE. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Garage floor same level as house a safety concern? | thorn2 | General Inspection Discussion | 11 | 1/25/10 3:33 PM |
| Garage Rafters NEED HELP! | Mitch Patel | Exterior Inspections | 8 | 9/12/09 2:43 PM |
| Garage door inspection procedure | bgromicko | General Inspection Discussion | 5 | 8/7/09 12:47 PM |
| Garage ceiling & door header | Al Barb | Interior Inspections | 7 | 3/27/07 12:07 PM |
