Old 11/15/06, 5:23 PM
apolillo's Avatar
apolillo apolillo is offline
Please Note: apolillo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Squash Blocks
Fellow Inspectors,
Hard to tell from the pics, but all the blocks were undercut a bit to much.
New construction $700K
Anatol
Old 11/15/06, 5:59 PM
Default Re: Squash Blocks
For another $150K they can have shims installed.
Old 11/15/06, 7:23 PM
thejnicki's Avatar
thejnicki thejnicki is offline
Any detail on the prints?
Old 11/15/06, 8:13 PM
apolillo's Avatar
The blueprints were not available. I know the blocks are wrong. They are supposed to be 1/16 longer than the I-joist. Funny this was, the other beam had the blocks installed properly.
Old 11/15/06, 8:24 PM
Anatol, The joists are not resting on the plate, but it looks like the blocks are. Maybe that's why there's a gap at the sheathing.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 11/15/06, 8:27 PM
Yes, yes they are.
Good catch.
Larry Kage, CMI
231 929 3525
Old 11/15/06, 8:36 PM
Many homes have no squash blocks at all installed when TJI"s are used. Who requires them to be 1/16" long, why and under what conditions?
(303) 717-8940
Old 11/15/06, 9:18 PM
Kenton, typically it's when there is a load bearing wall above that the blocks are needed. All manufacturers that I've used specify that they be 1/16" higher that the joist.
Larry Kage, CMI
231 929 3525
Old 11/15/06, 9:22 PM
I figured, Larry. Then they must be detailed by the engineer that stamps the plans. Is the +1/16" rule something required by I-beam manufacturers? Does that hold true whenever squash blocks are used in i-beam floor systems?
(303) 717-8940
Old 11/15/06, 9:50 PM
Yes, the I-joist manufacturer specifies the need and location on the installation instructions.
Larry Kage, CMI
231 929 3525
Old 11/15/06, 9:53 PM
Ah-HAH, thank you.
(303) 717-8940
Old 11/16/06, 9:20 AM
gkoehl's Avatar
gkoehl gkoehl is offline
http://www.ilevel.com/literature/TJ-9001.pdf
good booklet dealing with I-Joist specs
see page 5
George Koehl
Collinsville, TX
TREC# 9435
NACHI ID: 06092190
InTex Inspections
Old 11/16/06, 9:35 AM
bjones1 bjones1 is offline
Send a message via MSN to bjones1
Please Note: bjones1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Slightly off-topic, but you have a $700K house here and they used OSB? Cheap man, cheap!
Old 11/16/06, 11:22 AM
DaveyJ DaveyJ is offline
Please Note: DaveyJ is a non-member guest and is in no way affiliated with InterNACHI or its members.
Here where I am located $700,000-$1.5 million houses are a common thing and we always use 3/4 in TG OSB. That is the norm here. Its all about the bottom line. A couple years ago when 1/2 osb was almost $20 a sheet some houses only got the sheer panels sheeted. The other places on the house got black fiber board. I also saw no sheeting above and below the windows. The stucco guys would just put their foam and wire over it and procede like normal. I'm not saying its a good thing, but it does happen from time to time.
Old 11/16/06, 11:31 AM
tmels tmels is offline
Please Note: tmels is a non-member guest and is in no way affiliated with InterNACHI or its members.
not all OSB is cheap
and the good stuff is way better than plywood
wet construction weather like we have had this fall doesn't harm it
it doesn't warp,blister, peal, separate, stays nice and flat.
the only down side is it is very heavy to handle during installation
Blocks kicking out dnice Structural Inspections 11 2/3/07 2:11 PM
