Old 12/10/10, 2:32 PM
Rick Strand's Avatar
Rick Strand Rick Strand is offline
Default Stair stringer bearing
I need some opinions regarding the bearing of stair stringers. Is the bearing adequate in the below photo? Is there any information regarding this subject in the IRC or other reputible sources?
Rick Strand, CPI
CAHPI Associate
Strand Home Inspections Inc.
Calgary, Alberta, Canada
Serving Calgary, Okotoks, Airdrie, Chestermere and Cochrane Alberta
Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/10/10, 5:21 PM
Sean Fogarty's Avatar
Default Re: Stair stringer bearing
You would have to measure the length and width. It's just like any other type of framing, meaning it will require minimum standards for load bearing.
From what I can see, it may need a center stringer. You could suggest this if the steps feel like the flex or move when walked upon.
The photo provides very little visible info.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 12/10/10, 5:40 PM
David C. Macy's Avatar
David C. Macy David C. Macy is online now
This was on a recent Inachi course.
Required egress stairways, decks, balconies, and similar means of egress should be anchored to the primary structure to resist both vertical and lateral forces. The use of toenails or nails subject to withdrawal is not permitted
Old 12/10/10, 6:18 PM
David A. Andersen's Avatar
Yea, sure!
And I can see the 36" landing is okey dokey from here too!
"the bearing of stair stringers"; lets see if I can find that in the SOP.
Does that require "analysis"? Hummmm!
Did you say you were a Home inspector?
Opps, does Canada play by the same rules (IRC)?
I think Nick made a video for those that can't read well or take time to "research"...
BPI# 5015804
Unique Stringer Construction krigler Interior Inspections 7 7/7/10 10:04 AM
Stair rails greater than 4 inches. Question dnasser Interior Inspections 24 12/23/09 12:52 AM
2006 IRC Stair Code badair Interior Inspections 8 8/13/06 12:37 PM
