This was a two year old home. The beam termination was only visible on one end, the other side being finished. The supporting post was 6 feet from the end. I reported that the beam needs steel shims welded in place instead of the loose scrap wood used. Now the new owner questions the other side. Question; Does the distance of the support post matter or should this be properly shimmed?
| Find an InterNACHI certified Arkansas Home Inspector (and anywhere else in North America) |
The beam needs to be properly shimmed to the bearing wall. The support post is secondary.
That's what I thought, but it always helps to ask.
Thanks |
| Got a letter from ASHI's President today. | gromicko | General Inspection Discussion | 55 | 12/13/10 12:51 AM |
| Bonded to building Steel Structure Frame | mcyr | Electrical Inspections | 11 | 4/29/09 12:50 PM |
| Steel column to Beam Connection | jevans | Structural Inspections | 11 | 10/30/08 11:19 PM |
| Steel beam lateral support | Mark Ellison | Structural Inspections | 10 | 1/16/07 11:40 PM |
