Old 10/13/08, 7:04 PM
John Evans John Evans is offline
Default Steel column to Beam Connection
Can someone post the requirement for securing steel columns to the steel main beam. I thought they had to be bolted together, can't locate the information in the IRC. Thanks.
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Old 10/13/08, 7:16 PM
David P. Valley's Avatar
Default Re: Steel column to Beam Connection
John,
Here ya go...
ID:	24633 steel-column-beam-connection-beam-steel-support.jpgsupport.JPG
Old 10/13/08, 7:36 PM
Brian E. Kelly's Avatar
Old 10/17/08, 8:44 PM
pabrioux pabrioux is offline
John, I think that they can be bolted, welded or connected with bendable metal tabs. Column bearing plate must also be at least full width of beam.
Paul-Marc
Old 10/17/08, 9:44 PM
Here is a real and standard conection guys if it helps.
This would be your standard beam column support and beam to column attachment.
Hope this helps.
Marcel
Old 10/26/08, 4:51 PM
Hi guys,
Would you report this, as the column top plate in not at least as wide as the beam it supports?
Marcel, it's basically the opposite of what your picture shows.
Also, does anyone kow exactly how much welding is enough at these connections, when only welding is used? Is this enough, should it be all sides...?
Thanks a lot!
Paul-Marc
steel-column-beam-connection-steel-beam-column-connection.jpg   steel-column-beam-connection-steam-beam-connect.jpg
Old 10/26/08, 5:04 PM
Originally Posted by pabrioux View Post
Hi guys,
Thanks a lot!
Paul-Marc
Hi. Paul-Marc
Although this would be adequate to serve the purpose of stabilizing the column to beam, it would have been prudent to clean off and grind the unnecessary features that I see like that angle iron.
Typically, a two inch weld would be adequate front and back of the top bearing plate of the column. in this case, the weld looks amateur and might not be adequate should this column sustain any axial or lateral strains that we are unaware of.
I would recommend weld on both sides of the cap plate and grind and prime exposed steel. Welding to be done by qualified Welder.
Hope this helps.
Marcel
Old 10/26/08, 7:30 PM
Thanks for the info and advice
Old 10/26/08, 9:53 PM
The connection of steel columns, to me, falls under the classification of engineering. I try to be careful as how I call out anything I might feel is adequate/inadequate.
That being said the connection point should be secured.
Now if you show me the engineered drawings I will gladly inspect the installation and comment.
PS As for the welding, unless you actualy saw it being done, and know what you are looking at, do not even hazard a guess if it is correct.
Old 10/29/08, 8:28 PM
Hi guys,
Thanks a lot!
Paul-Marc
What's the purpose of that metal bar in the first photo?
Old 10/29/08, 9:57 PM
Holding the column plumb while being welded to the beam.
Marcel
Old 10/30/08, 11:19 PM
It demonstrates what crappy welding looks like.
Jees they could not even bother cleaning off the paint.
Beam Attachment to Column jhagarty Structural Inspections 3 7/25/08 2:37 AM
A steel House rcooke Canadian Inspectors 4 3/20/08 12:42 PM
Steel beam lateral support Mark Ellison Structural Inspections 10 1/16/07 11:40 PM
Steel beam bearing 1 1/2" scosta Structural Inspections 15 6/12/06 10:01 PM
