I see this as a standard setup in 1950s brick construction (residential) all the time, but the angle on this made me double take.
OK may have been this way fifty years ,but is this a issue I should point out or just a different configuration. These beams are always straight ,front to back of the home when I have seen them before. Should I be concerned? ![]() ![]()
| Need a home inspection in Virginia? Check out InterNACHI's listing of Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Nice paint job on the column Bob.
For whatever reason the beam is not straight is beyond me, but in order to do that, they had to splice the beam on the column where then, was there adequate bearing on the post.? LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Some were loose,(another common issue) So each section of I beam has two attachment points. No mending plates. |
That is standard Bob for post to beam connections
Ok so I guess the slight angle though unusual is not really a defect.
I will recommend tightening the bolts and adding mending plates. (sound right? |
Bob, you don't need mending plates for that.
The plate and the framing above is keeping everything aligned and stabilizing the rotation. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Now I can worry about the foundation leakage and the brittle asbestos tiles. |
Alabama Home Inspections www.thebirminghamhomeinspector.com Home Inspections in Birmingham, Montgomery, Huntsville, and Tuscaloosa. |
Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
These are friable. As mentioned above. Challenge is how to hire the proper contractor to remove the loose and brittle tiles that remain from years of wet flooring. These were crunching when walked upon. I informed my client it would be best to have them removed if loose ,before using an alternative floor cover on top. |
| screw lolly column | rjack1 | Structural Inspections | 27 | 1/23/10 11:22 AM |
| Steel Beam termination question. | tpetersen | Structural Inspections | 2 | 4/27/09 8:24 PM |
| Steel column to Beam Connection | jevans | Structural Inspections | 11 | 10/30/08 11:19 PM |
| Steel post question | sspradling | Structural Inspections | 42 | 3/2/07 9:59 PM |
| Support post for Beam, is this right? | mlong | Structural Inspections | 63 | 7/25/06 7:34 PM |
